Results 1 to 10 of 11
- Sep 2008
- 142
January 30th, 2015 06:49 PM #1is there any problem on the engine when oil is over the maximum limit based on the stick gauge during change oil? I got wifeys car for a change oil in a petron gas station, when i checked on the gauge stick the following day, the oil indicates over and above the maximum limit. its a vios 1.5 G car po pala.
January 30th, 2015 07:22 PM #2
Bad for the seals. Better keep the level between the min-max markings.
- 54,301
January 30th, 2015 07:31 PM #3i think the problem of over-filling with oil, is that the crankshaft's reciprocating arms might reach into the oil and act as an egg-beater. the oily foam that is generated might be sucked up by the oil pump. this oil-and-air mix may not provide adequate lubrication protection to the metal parts..
it is true that modern oils include an anti-foam additive... but why tempt fate?
- 54,301
January 30th, 2015 07:32 PM #4i think the problem of over-filling with oil, is that the crankshaft's reciprocating arms might reach into the oil and act as an egg-beater. the oily foam that is generated might be sucked up by the oil pump. this oil-and-air mix may not provide adequate lubrication protection to the metal parts..
January 30th, 2015 07:33 PM #5
Yep them stoopid oil changers. Next time tell them to put 3.5 liters (depending on your car)lang wag buhos lahat. Ikaw na mag top up. Just keep the extra oil.
Return to petron at bawasan via drain plug
- Aug 2014
- 391
January 30th, 2015 08:31 PM #6naisip ko lang, pwede kaya higupin ang oil via dip stick hole... pasukan nang maliit na hose then higop?
- Sep 2008
- 142
January 30th, 2015 09:16 PM #7i guess theres a rationale of the markings on the gauge stick, d sana nalagyan nga po!
Thank you for the advices, dr.d, oj88, jasonub, i have to go back tomorrow at the gas station. besides, the car emits white smoke upon engine start in the morning.
[SIZE=1]- - - Updated - - -[/SIZE]
- Apr 2014
- 473
February 1st, 2015 12:14 AM #8Eto ginagawa ko pag change oil. Sa Montero GLX 6.5L max oil capacity. I simply fill it with 6L of oil. On my Rio 2014, max nya is 3.7L. Service manual says fill 3.3L, however I do not trust the casa or anyone with correctly filling 3.3L. So I will simply buy 3L and call it a day.
User manuals specifically mentions, "DO NOT OVERFILL" the oil. Its better to be on the conservative side in this regard. Besides I'm very hands-on with my car's maintenance. I check everything can every 2-3weeks.
February 27th, 2015 11:28 PM #9
Nung 1K and 10K PMS ko sa casa, may natitira pang a few hundred milliliters of oil sa one gallon container nila. Ngayon wala na. Nung nag-check ako recently sa dipstick, lampas sa full line. Kaya ngayon, sa labas na ako nagpapa-change oil. Around 3.7liters of oil lang ang nagamit ko and the oil level is just below the full mark.
- Nov 2014
- 454
March 18th, 2015 11:49 PM #10Same here, though hindi naman ganon kataas yung isinobra. PMS ko last Monday sa casa, kanina ko lang ni check siguro an hour after pinatay ko yung engine. Me factor ba yung time at init ng makina pag check ng oil? Try ko ulit tomorrow morning.
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
