Quote Originally Posted by Jie11 View Post
is there any problem on the engine when oil is over the maximum limit based on the stick gauge during change oil? I got wifeys car for a change oil in a petron gas station, when i checked on the gauge stick the following day, the oil indicates over and above the maximum limit. its a vios 1.5 G car po pala.
i think the problem of over-filling with oil, is that the crankshaft's reciprocating arms might reach into the oil and act as an egg-beater. the oily foam that is generated might be sucked up by the oil pump. this oil-and-air mix may not provide adequate lubrication protection to the metal parts..
it is true that modern oils include an anti-foam additive... but why tempt fate?
