Results 1 to 10 of 48
Threaded View
September 19th, 2016 09:51 AM #18
since you have the diagnostic trouble codes, start from there.
check your voltages at the MAF connector
blue/black battery voltage with KOEO (key on engine off)
gray/green less than 1 volt
gray/black 1.8 volts at 20 degrees celsius
2.2 volts at 30 degrees celsius
violet/white less than 1 volt
black/orange 0.7 volts KOEO
1.3 volts after engine warm up
