Results 1 to 20 of 20
    Dec 2009
    Guys noob question lang. Ano kaya ibig sabihin nun? All of a sudden habang nag d-drive ako bigla na lang syang umilaw. Thanks!
    Posted via Tsikot Mobile App
    Jul 2011
    Quote Originally Posted by radz15 View Post
    dba check engine light (CEL) yan?
    Dec 2009
    No idea sir. Bat kaya bigla nalang umilaw habang naka bukas makina. Nung sinubukan kong patayin makina tas binuksan nagkaroon uli ng ilaw yan. Hmmm... :confused:
    Jul 2011
    kung CEL nga yan, kailangan mo ipa-scan para malaman kung ano ung error na nakita?
    pwede mo ba kunan ng mas malapit? mukha ba syang engine block?
    Jul 2011
    sorry sir nde pala CEL yan
    Aug 2012
    disesel engine ba yan?
    Water In Fuel indicator
    Diesel powered vehicles are equiped with separators that remove water from the fuel. These filters need to be serviced periodically. This filter system is termed a Diesel Fuel Conditioner Module (DFCM) by some manufacturers.
    Water in Fuel Indicator Symbols | DashboardSymbols.com
    The vehicle is safe to drive, but the water should be drained as soon as possible. However, if you have just re-fuelled, the fuel may be contaminated. The engine should be switched off as soon as possible or the fuel injection system could be damaged.
    Dec 2009
    Thanks sa info sir. Lagi ako nagpapa karga dun sa gasolinahan na un at di naman nabaha para mahaluan ng tubig yung crudo nila.. Hmmmmm... Magkano kaya paayos ng ganito?
    Aug 2012
    the fuel tank needs to be drained and flushed, and then refilled with diesel.
    Dec 2009
    Eto sir mas malapit na kuha
    Dec 2009
    Diesel sir. 2011 mitsubishi adventure.
    Aug 2012
    okay, tama nga. actually, your vehicle Owner's Manual should contain that info already.
    Oct 2011
    Baka pwede pump out mo muna ung water sa fuel/water separator sir radz! Then close the plug and see kung mawala na yan ilaw sa dashboard.
    Dec 2009
    Thanks sir. Kaso zero knowledge ako sa ganyan. Hehe pwede kaya paayos to sa gasolinahan? para derecho pakarga nadin.
    Dec 2009
    Na check ko sa manual. Ang sabi remove the water from the fuel filter. Kaso d ko alam kung pano. Hehehe check ko sa youtube baka kaya za DIY.
    Oct 2011
    Usually may plug yan sir sa ibaba ng fuel/water separator. Luwagan mo lang un and then pump mo sa ibabaw hangan sa drain na lahat ng tubig. Close mo valve and then pump it again then start your engine it should be gone by then.
    had the similar issue with our montero. but the dash only lights up when you step on the brakes. is this also a symptom of water in the fuel system.?
    Dec 2009
    thanks sir. Check ko bukas ng umaga.
    Sir is the owners manual still with the car? The step by step way to remove water from the fuel filter is detailed there. Being the lazy guy that I am, I paid around 200 for the neighborhood mechanic to drain the fuel filter and pump the air out.
    In hindsight, I should have just replaced the fuel filter since the filter isnt terribly expensive and the labor rate would be the same.
    Dec 2009
    Ok na mga sir. Naayos ko na salamat sa mga tumulong. Hehe dami pala matututunan pag nagbabasa ng owners manual :D
    Aug 2012
    just like any device, you will only learn the full features if you read the owner's manual. specially important basahin ang maintenance section.
Need help! All of a sudden biglang may umilaw sa dashboard
