Results 1 to 12 of 12
    Oct 2005
    when I checked the radiator while engine is running I can see very little bubbles. The bubble size are the size of softdrinks spirits and I can smell gasoline from the coolant reservoir, however water is clear and no sign of oil in it. The oil on the dipstick and oil cap doesnt have a trace of water either. Color reddish black pa yung color ng oil and doenst feel waterly when touched.
    Im assuming blown headgasket or cracked valve guides here but im not really sure. My mechanic told me ok pa naman but were not sure kung tatagal pa yun head. What do you think?
    Feb 2009
    Quote Originally Posted by badtoy View Post
    badtoy,
    what make, model, year, fuel delivery system type? if it is carbureted, some of the carburetors have EFE(early fuel evaporation systems when the engine is cold and the the antifreeze/coolant has a passage in the carburetor. put it in mind, that the fuel pressure in a carbureted engine is lower than 5 psi and that the antifreeze/coolant is at around 13-15 psi.
    jick
    Oct 2005
    Hi Jick. Im sorry I forgot to mention the engine. Its a 4AGE redtop corolla engine. Its originally found on a 92 model corolla in japan. Its EFi so i guess that EFE system isnt considered.
    Oct 2005
    wala naman syang bulwak pag inistart. No history of overheat as far as i know.
    malamang may minor leak ka sa cylinder head gasket or a little warpage in your head. but it is still minor,mag tatagal pa yan, pag ipunan mo ng 6 months then pede ka na mag sabay ng piston ring and valve paayos (dukot or top overhaul).
    Oct 2005
    thanks reym.
    mejo hindi lang ako kampante baka biglang magoverheat especially nowadays na napakatraffic due to rainy weather.
    Pag rainy seasons, the rain and cool air contributes to the cooling of the radiator and coolant. Another thing that contributes to cooling is the minimum use of the air conditioning.
    Lagi mo lang check ang coolant mo, dapat ata 50% coolant and 50% water depending on the manufacturer.
    Tol ,subukan mo munang lagyan ng tubig ang radiator puno huwag lang apaw . Tignan mo iyong radiator tangal ang radiator cap at pa start mo makina ng sasakyan .Pag nakita mo na bumulwak ang tubig head gasket iyan . Kasi noong pinapalitan namin ng head gasket itong nissan nawala na na ang pagbulwak ng tubig pag start ng makina. Iyon naobserbahan namin wala naman mawawala . Give as feedback na lang.
tatagal pa kaya ang cylinder head?
