Results 1 to 10 of 12
July 22nd, 2010 03:25 PM #1
[SIZE=2]patulong please. i just bought a 1996 model strada with 4d56 turbo engine. maingay po makina at high RMP. tiktiktik po ang ingay pag mataas na rpm around 2500 and above.
this are the things i did just to solve the tiktiktik sound at high rpm
1. clean nozzles tip
2. calibrated the injection pump
3. change the rocker arm to roller type
4. valve clearance adjustment (4 times na with different mechanics) tried straight 10, 12 and 14. 10 ang current na valve clearance.
note: wala naman po blowby makina. hindi rin kumakain ng langis. okay naman ang andar kung idle lang sya. kapag mataas lang rpm tsaka maingay.
ano kaya pwede pa check para ma solve ito. i tried browsing all the thread pero wala ako mahanap na related sa problema engine ko so i post this thread. also kung sino man may workshop manual ng 4d56, kindly send it to me at cadayjerry*yahoo.com[/SIZE][SIZE=2] hindi rin sya hard starting, malakas ang hatak.[/SIZE]
- Dec 2009
- 47
July 23rd, 2010 10:32 PM #2ui wait din ako ng sagot dito ganito din ang space gear ko 4d56t grabe ingay
July 23rd, 2010 11:54 PM #3
Nagpalit ka ba ng brand ng oil sir? Sakin kasi di naman ganyan ang ingay pero nung nagpalit ako ng oil mas tumahimik ang makina compared don sa unang oil ko na nagamit.
- Jun 2010
- 76
July 24th, 2010 10:20 PM #4try nyo na adjust na maiinit yun engine .10 mm ang valve clerance kung ganon pa rin malaman na may problima yun valve seat..kailangan baba ang cylinder head para makita yun valve and valve seat.
- Sep 2006
- 1,335
July 24th, 2010 10:56 PM #5[SIZE=2]patulong please. i just bought a 1996 model strada with 4d56 turbo engine. maingay po makina at high RMP. tiktiktik po ang ingay pag mataas na rpm around 2500 and above.
1. clean nozzles tip. Maganda pa ba ang kundisyon ng nozzles kaya pinalinis mo lang? 14 years old na yan kung hindi pa dating napalitan.
2. calibrated the injection pump.
3. change the rocker arm to roller type.
August 2nd, 2010 04:34 PM #6
yes sir, maganda pa yong nozzles tip. napalitan na ito kasi bago pa nong binuksan. natanong ko na rin dati may ari, 1 year daw ito pinalitan. binigay nga sa akin yong pinagpalitan. mukhang ito rin problem ng dati may ari kaya nya binenta. na overhaul na pala ito 2 years ago. after 1 year daw ganyan na naging tunog. pero wla naman blowbye. hindi sya hard starting. hindi rin kumakain langis.
yes nagpalit na rin ako langis. from shell yong dati gamit to rev-x trekker. ganon pa rin. mainit yong makina nong pina valve adjust ko ng .10. na try na namin 12 and 14. malakas naman hatak, hindi sya mausok pero maingay.
balak ko pabuksan cylinder head para makita valve and valve seat. kaso wala pa budget. baka biglang may malaking tama sa loob at wala pang gastos.
August 2nd, 2010 04:40 PM #7
marami na ako pinuntahan na shop para lang pa check up at kumuha opinion nila. may nagsabi palit ng camp shaft. meron din nagsabi baka sa valve seat na kailangan palitan na valve seat and valve. may nagsabi baka sa piston pin daw. at meron din nagsabi pa reface yong cylinder head.
waiting pa ako iba opinion habang nag iipon. yong mga expert dyan baka may experience kayo ganito.
thanks po......
August 12th, 2010 11:17 AM #8
add ko lang, as per the workshop manual ang sabi e 0.15 mm for intake and exhaust ang valve clearance. pero ang ginawa ko last tune up ko e 0.25 mm. yun ang nakikita ko sa mga pajero na 4d56 e. i think ung tiktiktik sound is on the valve train system. nakakabit pa ba yung mga injection pipe clips?
- Jul 2003
- 573
August 15th, 2010 10:48 PM #10
kung pag start mo may tiktik sound o kaya pag init ng makina nagkakarun ng tiktik sound tapos nag acelerate ka sumasabay ang tiktik sound,,,itakbo at naka idling lang ang sasakyan may titik sound malamang sa piston pin yan..
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
