Results 1 to 10 of 14
Toyota is my choice
- Aug 2005
- 2,063
June 10th, 2006 12:16 AM #1Nabasa ko na lahat ng threads regarding ng idle problem pero di ko malaman ang anong prob ng auto.. nakakaloko talaga tong 1.3 carb corolla big body ng daddy ko.. argghhh.. sana lng bilhan nlng ako ng bago.
When A/c is off wlang problem talaga maganda ang idle at hatak .. Pero.. tsk.. kpag nka A/c On 950 or minsan 1000 rpm okey sya pero kpag automatic Off na ang a/c kasi malamig na biglang sudden drop na parang nagloloko ang idle at nag choke yong engine parang maputolan ng hininga "kruggg" "kruug".... hehe..
the worst thing ngayun kasi ginalaw ko idle Namamtay na talaga ang engine while engaging full stop and neutral a/c on..
Hindi ko pa na check ang servo kasi di ko alam kung ano yun.. pati yung idle up or base idle or may leak bah kaya? .. ano kaya prob nito? ayaw ko nman ipagalaw sa mechanic kasi tira lng tira gastos lng ganun pa din. okey nman ang engine nka tuned lahat pero kpag nka a/c Deadoks talaga.
June 10th, 2006 12:22 AM #2
check mo idle up switch if its still working. remove mo one hose yun papuntang vacuum see kung may lumulusot na air while you turn off/on your aircon. if its working put it back and see if the vacuum mechanism still works ( pulling and releasing action). check your rubber hoses for leaks.
June 10th, 2006 12:23 AM #3
Pagbagsak ba ng rpm e umaakyat ulit? Tipong nagdidive? Sakin kase ganun problem ko before. Pag may aircon lang. Pag unang andar medyo hindi pa ganun kababa ung bagsak pero after driving for a couple of minutes, sobrang baba na to the point na namamatayan na ko makina. Pina-check ko kay Mang Mario yung aircon. Hindi daw sabay yung pag-disengage ng compressor and the fan. May inayos na wirings and fuse and viola! Ayos na! That was around February this year and until now wala na problema.
Hope this helps.
Toyota is my choice
- Aug 2005
- 2,063
June 10th, 2006 09:37 AM #6waaa.. RORO ang layo.. huhuhu..
basta sakin kpag nag TRIP off na yong aircon dahil subrang ginaw DEAD talaga engine ko. while full stop.. arggg... kakainis talaga to prob nato.. Manong Mario help!
June 10th, 2006 09:48 AM #7
if it's 1.3 carb tingin ko idle up pa yan e, di ba wala servo ang carb? marami naman mabibili idle up sa surplus shops---300petot onli
Toyota is my choice
- Aug 2005
- 2,063
June 10th, 2006 09:50 AM #8Originally Posted by fakesaint
sir.. san makita ang idle up.. pano malaman if yung ang not working.. gumagana nman idle up ng AIRCOn pero kpag nag Off na compressor dahil sa subrang ginaw ayun.. DEADOKS na
June 10th, 2006 11:47 AM #9
for my 1.3 big body, ganyan din ang case, 700 rpm w/o aircon ok, but pag on na ang A/C die down na ang makina, so I raised the rpm to 900 sa idling control para di mamatay ang makina pag naka on na ang a/c.
June 10th, 2006 12:01 PM #10
Taga Cebu pala kayo. Kase kung nangyayari lang yan with aircon on, more or less the problem is with the aircon.
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
