Results 1 to 6 of 6
    Jun 2004
    Guys, help naman . May car, Nissan Altima AT 1995 does not start. New battery. Bale hindi ko nagamit ng three days then I tried starting it, pero super hard start na (well hard start na sya matagal na), it will crank the engine a bit until wala na talaga, clicks na lang maririnig ko, then i tried again after few days wala na talaga, wala na ring mga lights, clock, dome light, etc.
    Ano po problem, solenoid? Starter or Alterntor?
    Recommend naman po ng mag home service (Mindanao Ave, QC), just to start my car para madala ko sa mechanic/shop.
    Maraming salamat.
    Jun 2010
    wala nang charge ang battery kaya ayaw nang mag crank , try mo muna palit ng good battery, check mo rin distributor after mo mag palit ng battery, hugot mo hi tension wire na naka saksak sa isang spark plug then pasak mo screw driver then ilapit sa cylinder head cover bolt saka start check mo kung may kuryenteng lalabas or spark .
    Feb 2009
    Quote Originally Posted by philander View Post
    Maraming salamat.
    from your description: new battery
    clicks but won't crank over
    finally does not even click
    are symptoms of a fully discharged battery. if the new battery was fully charged, there might be a drain on the battery that discharges it in a few days. check for switches that might have been left ON while the car is parked. check your battery connections for corrosion and tightness.
    Jun 2004
    Nag series ako ng battery. Nagkaroon sya ng ilaw, then when I tried to crank, ayun click lang then completely walang ilaw ulit (discharged again), then when I revert the key, magkakailaw ulit.
    Need ba talaga completely charged yung battery? Or starter problem na?
    Jun 2005
    dapat completely charged. try jump starting with another car
    Are you really using a new battery?
    Have you tried checking the battery cables?
Nissan Altima - Car wont start, new battery
