Results 1 to 20 of 20
    Sep 2014
    Good day ka-tskikots!
    I have a Lancer Boxtype model which was a pamana from my grandad and also my first car. It seems may problem sa carburetor which is leaking fuel around the base sa may hole kung saan nakalagay yung throttle ata yun. May repair options pa ba yun or I'll need to buy a replacement carb? If so, where and around how much? Thanks!
    Malamang seal lang na sira.
    Rebuilt kit pwede diyan sir, hindi lang ako familiar kung saan meron.
    Feb 2014
    Congrats sa 1st Car mo TS
    Regarding sa Price ng pa repair ng Carb nun August ata nag pa repair rin ako ng Carb sa may Novaliches Php750 ang siningil sakin.
    Sep 2014
    Quote Originally Posted by [archie] View Post
    Panong seal po? Kasi parang maluwag na yung sinusuksukan ng throttle plate kaya may tumatagas na gas sa may space na yun.
    Ahh gasket lang pala. Kasama ata sa repair kit yun.
    May mga rubber seals yung carb or o ring kung tawagin. Kala dun tumatagas.
    Sep 2014
    Di ko maexplain ng maayos haha. Di sa may gasket yung leak e. Hmm yung leak kasi sa may part ng throttle plate na nakakabit sa mismong base, example etong hole > O tapos nakasuksok dyan di na sakto sa hole na yan kaya may space para tumagas yung gasoline. Eto sana maintindihan ang drawing kong malupet haha.
    Bro Parang o ring lang. Hindi ko din sure.
    Pacheck na lang pero mura lang rebuild ng carb.
    Sep 2014
    San po pwedeng magparebuild? Manila area.
    Try mo Prime, buendia cor. slex.
    Eto yung cast iron part ng carburetor, right below ng aluminum floater tank at injector. Had that same experience before sa boxtype ko, nung sinubukan kong baklasin wala akong nakitang seals, I guess lumuwag na yung shaft casing (yung naghohold ng throttle valve) due to wear. Nagtanong tanong ako sa shops and they recommended na either bago o surplus. Swerte nakakuha ako ng surplus (yun throttle body lang na cast iron) sa may evangelista, mga 450 pa bili ko nuon. Pero that was way back 2006 pa
    Oct 2009
    Quote Originally Posted by Paul Valencia Ü View Post
    O ring yan TS mas maganda kung bili ka nalang ng isang buong repair kit.tapos pa overhaul mo ung carb mo sa mekaniko siguro mga nasa 500 ang labor para sigurado kana
    Jan 2011
    sir, if malapit ka lang sa kamuning. i suggest doon mo ipa overhaul ang carb mo. hanapin mo yong rommels carb. right side from edsa, kasunod ng bpi yata yan. may machine shop din kasi sila. affordable price at quality work.
    Jan 2011
    Kung na aalala ko pa, Aisin brand ng carb ng Lancer box type. Yung mas lumang Lancer (egg type) Solex. Kung kaya mo lang, palitan mo ng Solex. Mas matipid at mas responsive I to kes sa Aisin.
    May 2018
    hello mga boss, alam ko 2014 pa to, pero baka sakali lang
    anu po gnawa nyu dun sa leak ng carburetor nyo po?
    kakabili ko dn po kc boxtype, first car dn, at meron dn leak sa part na yan ng carburetor nya pag binobomba ung gas ped habang naka patay pa sskyan, pero kung umaandar naman na wala na ung leak.
    salamat po.
    Quote Originally Posted by handsum View Post
    salamat po.
    perished gasket and/or loose screws, are a common cause of carburator leak.
    another cause is float mal-adjustment.
    another would be float valve malfunction, i.e., dirt.
    they may be repaired "relatively easily", or replaced if irreparable, provided spares are available.
    errr... is your "leak" really a leak? or is it normal function? or is it the result of gas reservoir overflow due to float or valve malfunction?
    if your leak is external, then it is definitely abnormal.
    salamat po.
    Sus, madali lang solution dyan. Yung second car ko noong araw Lancer Box type. Ang carbeurettor nyan AISIN. Di naman masyadong nag wawarp yung base nya, unlike yung sa Dodge Colt 1600 na Solex. Yung dalawang yan interchangeable kasi yung intake manifold nila pareho. Ang usual nag leak dyan ay yung base gasket. Kailangan ka lang humanap ng gaskets at repair kit. Yung repair kit may gaskets at replacement jets. May parts at mechanics na magaling dyan sa Prime Automotive and Components 95, Senator Gil J Puyat Avenue, Makati, 1200 Metro Manila. Nag google lang ako kasi dun ko noon dinadala yung aking Lancer. Di ko lang alam kung buhay pa sya. Good luck
    old carburators are sometimes difficult to service, because of lack of spare parts.
    kung gasket lang, madali 'yan.
    use the old one as pattern, and make your own.
    the materials are easily available from the well-stocked auto parts stores.
    "the finished handmade product does not have to be a beauty queen. it just has to have the right curves and holes."
    True, you just have to do the legwork & search. But it is definitely still available. One thing with the Aisin or Solex carbs of that model, it is easy to dismantle, clean, repair etc... because they are mechanical. It just works on levers. The ones I wouldn’t touch are the Nissan Sentra carbs. It has so many sensors to foul up.
    Between the Aisin & the Solex, I prefer the latter. When I swapped the carb of my old box type to the Solex, fuel economy improved to 12km/ liter from 9. Thats why if you can get your hands on a Solex...
    But seriously, that's so true. In many cases, it's way easier to just trim the excess edges after you have mated the surfaces together. That's only if you don't have the old one to use as a template.
Lancer Boxtype Saturn Engine Carburetor
