Results 1 to 10 of 10
    Sep 2006
    -nakabypass kc main relay ko temporarily dahil sira .... what are the disadvantages? thanks gurus
    Sep 2006
    Pwede ma-overload, mag-init, at masira ang ignition switch. Yung main relay ang dapat mag dala ng high current electrical load.
    Jun 2006
    Replace your main relay. Dont scrip on safety, specially this is a electrical device.
    A relay is like a switch, it controls the electrical load.
    Apr 2008
    tama sila dieseldude at userfriendly saka kapag walang relay baka masunog ang device na kinakailangan relay kay habang maaaga pa ay palagyan mo na ulit ng relay yan kung ayaw mong magsisi sa huli
    Dec 2007
    I also agree. MAIN relay pa naman yan. Kung yun ngang busina, nilalagyan ng relay, yun pa kayang load ng Main relay?
    Replace it right away.
    Isipin mo na lang na ang low current side (maliliit ang wiring normally), e pasukan mo ng high current.... Delikado....
    8101:oops2:
    Jul 2003
    maki-ride ako. how much ba main relay? specifically for honda civic esi (93).
    yung kasing engine light pag turn ng ignition key to ON ay ndi nawawala after 2 secs. mukang main relay kaso wala ako mabili.
    MITSUBA yung brand.
    Sep 2006
    Quote Originally Posted by fourtheboys96 View Post
    MITSUBA yung brand.
    meron sa HCP nakabili ako kahapon 500 lang.somewhere in mindanao avenue... i can give you the number
    Feb 2009
    Quote Originally Posted by MasterZerg View Post
    masturzerg,
    this is a bad habit, don't do it again.
    should you need to get out of traffic jam while your relay is inoperative, use a fused jumper with a fuse rating equal to or a tad bit lower than the circuit involved. if it was on the control side of the relay, still use a fused jumper using a two amp or a five amp rated fuse. once you get out of the traffic jam, have your chariot checked by a qualified auto electrician. it is always a good habit to carry an ABC type fire extinguisher in a car aside from a first aid kit. think safety!
    jick
    certified auto
    guam
Disadvantages of bypassing the main relay
