Results 1 to 10 of 41
December 14th, 2011 02:15 PM #1
Not always true.
Using a different type of oil does not automatically extend oil change intervals unless the engine can take advantage of the properties of the synthetic oil. If the oil gets dirty, it gets dirty, and must be changed. The idea that "fully synthetic" automatically means longer intervals is one that many ZZ-equipped Corolla owners have discovered to be, sadly, not applicable in their case. (look up Toyota sludge issues)
Many CRDis already require fully synthetic oil, but still use 5,000 km intervals for local conditions. This is because Philippine conditions are considered harsh. This is not to say that the oil is useless by 5,000 kilometers, but unless you have access to an analyzer, do you want to take the risk?
December 14th, 2011 03:24 PM #2
I use Zic or Kixx semi synthetic oil for my Tucson and Santa Fe. Change oil every 5000kms since mura Lang naman yung oil. 1,150 pesos per gallon lang yung oil. 2 gallons needed.
Ilan liters ang oil ng Captiva?
I already used Motul CRDi Specific. Parang yung Kixx Lang eh. Mahal pa. So sayang Kung papalitan ko every 5000kms. Ayoko naman isugal hanggang 10000kms yung engine oil kasi madumi talaga kapag diesel engine.
- Apr 2006
- 351
December 27th, 2011 05:54 PM #3I used Kixx oil for my Captiva on my last oil change (80K PMS) I got the 6 Liter container available at Seiring. The Captiva uses 6.2 L of oil. Tamang tama lang yung 6 liters na kinuha ko. It's a lot cheaper than what casa sells and other semisynth and full synth oils. Maganda naman siya and it has the same specs as the Motul crdi specific oil. I'll stick to this brand and change oil every 5k. I beleieve it can last 10k with good filter but I don't know if i can find one fleet filter. Satisfied ako with Kixx . Engine seems smoother than with the oil from casa.
- Jul 2011
- 584
December 28th, 2011 12:16 AM #4how much sir yung KIXX oil? parang napakamura naman nakita ko sa online store
Lubricants | Fleet Fuel Philippines for PhP3,500 you will get 3x 6L of kixx oil.....
- Jul 2011
- 584
December 29th, 2011 06:24 PM #6mga sir yung KIXX OIL ba ng sinasabi nio nabibili sa Seiring ay ito KIXX D1 API CI-4 10W-40? and how much?
- Mar 2012
- 1
March 21st, 2012 02:00 PM #8I had gone through the post.; I did the first oil change at 15k km when yearly 20k km was recommended. Now, In the next oil change we did at 20k km. This was good enough for the CRDI car with VGT. Please produce some more attachment links for the detailed view of the topic? Thanks in advance.
quick oil change coupons
recommended oil change interval
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
