Results 1 to 3 of 3
    Jun 2012
    My car's idling sporatically changes. And it usually turns off whe I turn on the A/C. Now I set the idle to high to make it run but I'm concerned with the fuel consumption. Can someone recommend a good carb mechanic near monumento area? Banawe is ok but I don't know anyone who specialized in carbs there.
    Nissan Sentra LEC 95 - GA13 Carb type.
    Jun 2012
    Up ko lang po pls help
    Ganyan din po ang naging problema sa Sentra ng father ko, GA14S ang engine. Pinalinis nya yung carburetor kaya OK na ito. Marumi lang daw. May instances din namang vacuum leak ang problema.
    Try mo kina Natoy/Mang Jaime near Mayon St. cor A. Bonifacio Avenue, QC. But if you're willing to take it a little farther, dun sa Kamuning * A&M shop.
    Last edited by jjmd3_787; August 12th, 2012 at 10:26 PM. Reason: tao lang po . . .
inconsistent idling and car turns off when a/c is on
