Results 1 to 6 of 6
    Aug 2006
    Hi ang Civic ko medyo tumotopak ang idling kasi pag naka stop minsan ako umaakyat baba ng mabilis para kang nag rerev na tuloy tuloy na up and down from 800 umaakyat sa 2 tapos bababa mabilis siya tried cleaning airfliter and ung sensor sa tubo
    Mar 2004
    sir you're problem might be the ICV or idle control valve. this is located at the rear of the intake manifold. it controls the idle of the engine specially when a/c is on.
    cleaning usually does the trick. except if the ICV is damage. then you can replace with surplus or new part.
    Aug 2006
    i encounterd also that problem nung nangyari sa akin yan nilinis din tapos nilagyan ng silicone yung throttle,,edi ok na tapos pag tagal blowby mine is a b16v laki ng nagastos ko
    Aug 2006
    many thanks i found the problem and it is true thanks a lot!!!
    Aug 2006
    * cobalt blue,, ano naging problem niya??
    Nov 2003
    have the throttle and iacv cleaned.
Idling on CIVIC Vti Weird problem
