Hard break-in or Soft break-in? May advantage ba talaga pag hard break-in?
i tried both. mas effective yun hard break in. pero hanggang 100 kph lang. masgumanda performance ng makina compare dun sa soft break in.
I don't believe in soft break in.
Ako pagka lagpas ng 100 kms hataw na. Kahit lagpas 100kph
I drive the car normally. No use babying the car. Just follow the manual.
No unnecessary hard acceleration, don't stay at one speed for extended periods of time.
For the first 300 km I try not to go past 4000 rpm. Until around 800 km I didn't push the car to redline, but I gradually accelerate to about 160 kph. From 800-1000 I pushed a little more but not sustained speeds. After 1000 km PMS yung totoong hataw na top speed for extended periods.
Plus ... avoid sudden starts and stops. Don't overload, avoid going steep uphill with heavy load.
Bro what i can advice is to read the owner's manual. Follow what is written and your car will be fine. That is your best bet and one of the most important thing that a new car owner failed to do. Wag ka masyado ma overwhelmed sa advice ng iba since not everyone is the same. Some may work for others car but it doesn't mean it'll work for your car.
^well, if it's the same engine, same car and all, then what works for the gander also works for the goose. and experience is the best teacher. that's why we are here sharing our experiences.
Sa case ko simple lang yung instructions sa manual, keep revs between 2-3k, no towing, or racing the engine.
imo, no need na ng soft o hard break-in. as bro jut said, no babying and drive as you normally do. di na applicable ngayon yan sa mga modern engines at ang mga spare parts ay gawa na sa mas matitibay na materyal. yung mga langis din ngayon ay masyadong advance din ang technology at sari-saring additives na kasama para maiwasan ang wear and tear. ihataw na agad yan para malaman mo ang response ng makina habang bago pa at ng may comparison ka kung sakaling humina and hatak o iba ang andar. saka kung may deperensiya man, malalaman mo din agad at pwede mo i-claim kasi under warranty pa.
Hard Break-in...
Kasi dyan nyo po malalaman agad kung merong defect/issues yung makina during first 1000KMS,
yung unang saksakyan namin, hard break-in, galing casa, takbo agad sa macapagal ng 120KPH, (2004) 11yrs na, no problem at all,
last year, nakabili ulit kami ng sasakyan, bago ko tanggapin yung unit galing sa casa, na-rev agad ako ng 4K RPM, for one minute, (diesel kasi) para malaman ko kung mag-emit bigla ng black smoke, or mag-iba yung tunog ng makina,
then 110KPH speed run agad...after few days, nakapag- 140KPH agad yung takbo, (wala pa po sa 100KMS sa odometer)
As much as possible "Extreme Caution" pag break-in period, test lahat po as much as possible, maliban sa engine performance, sa braking at handling capability...
and very important po, during break-in period, lalo pag long rest ang makina, during cold-start, let the engine warm-up, (off ang accessories, a/c off din) once na umabot na sa normal temp....saka patakbuhin...
Yun nga eh...
Kwento nga sa akin nun isang kasama ko sa work ngayon na noon nag work pa sya sa assembly plant eh pagkatapos daw i assemble ng saskayan eh papatakbuhin agad ng mabilis yan na naka disconnect yun odometer para makita nila agad kung may problema. Kaya pinapayo nya minsan sa mga kakilala nya na may bagong bili na sasakyan eh wag na mahiya kasi na break in na sa planta pa lang.
Eto naman kwento ko hehe
Noong araw na nag work ako sa isang gasolinahan eh may customer kami na may bagong Accord. Then nagulat sya kasi halos lahat ng pump sa gasolinahan ay puno ng mga bagong Accord. Ito pa kasi yun time na uso pa yun mga pull out drivers. Malapit lang kasi noon yun PDI nun Honda sa amin kaya nasa fleet account sila. Sabi ng customer eh buti na lang dito ako nag papagawa sa inyo kasi dito pala nagpapakarga mga bagong Honda. Nang biglang - screeetch! Bawat isang Honda kada tapos makargahan ng gasolina eh pinapaiyak nun mga pull out driver yun mga gulong. Kaya nagulat si customer. Huh? ginaganyan pala nila? Kaya sabi namin eh atleast tested na yun mga saskayan bago dumating sa customers! Napakamot na lang si customer at sabi sus, ingat na ingat pa naman ako....
Yun nga eh...
^ nice story sir. Hehe. 😆
Naniniwala din ako sa hard break-in eh subok na sa mga auto namin.
The engine oil that came with the new car is thinner than the regular oil. Cars at the end of the assembly line are tested at high rpm to measure torque and evaluate engine performance and to evaluate wheel alignment should there be a need for adjustment. But when you buy the car, they RECOMMEND you avoid frequent hard acceleration, avoid carrying or pulling heavy loads and avoid high no load engine speed at least until after the first 3000 mile (5000 km) where they "supposedly" check the drained engine oil for solids suspended in the oil and listen/observe the engine for abnormal noise and vibration. You as the owner have the right to abuse your car. When it breaks, the dealership shop verifies whether the malfunction or damage was caused by abuse, neglect or defect in engineering, materials or workmanship. Afterall, you bought the car. It is beyond warranty if the owner so desires to destroy the car once he pays for it.
Yan din sabi sa Amin ng service advisor sa casa,wag nyong I baby kotse,baka masanay eh gumapang na Lang yan![]()
Cars and light trucks change the oil on the 1st 1300klm
Medium duty and full size pick up 1st 4000 Klm
Heavy duty 1st 12000 Klm
Just to remove the break in materials from oil same as our new,reman or new overhaul engines and trans
We never break in our new unit we just put them to work its brand new so we wanna test it if anything goes wrong it's under warranty.
iba ang procedure.. soft break in pag bagong overhaul. brand new engine, all parts of the engine are brand new unlike in newly overhauled engine that have brand new and used parts that may not have seated together properly
