Results 1 to 16 of 16
    napansin ko kaninang umaga pag bunot ko ng dipstick sa e150 medyo maitim na ang oil ko pero 3500 kms palang natakbo nito and yung altis namin 7000 na tinakbo pero magkatulad lang sila ng oil sa e150. theyre using the same exact oil and same exact viscosity, both synthetic.
    twice ba kabilis mag oxidize ang oil sa v8 than 4 cylinders due to additional displacement and cylinders?
    does the displacement had to do with it?
    TIA
    It does get darker sooner since it also tends to generate more heat. When I had my lancer with the 1.5L 4 cylinder I could change oil and it would be a about 3 days of use before it would start to get dark. But with my Xterra with a 4.0L V6 it changes color after just one use of the truck. You have to remember with a V8 you have twice the cylinder count which would generate twice the carbon that the oil will pick up.
    Aug 2004
    It's probably down to the design. The Altis engine is designed with tighter tolerances, so the potential for oil contamination is less.
    Also, check your E150's tuning... from the sound of it, the engine is probably running pig-rich and the oil is picking up extra carbon deposits from the cylinder walls.
    niky, what is pig rich?
    sorry noob.
    Aug 2004
    Drinking too much gasoline. The unburned gasoline is left as carbon deposits on the cylinder walls and washes into the oil. Some AFR tuning might help, but I don't know anyone who can tune a Triton.
    Nov 2003
    depends how dirty it was before. if the engine of the ford was dirtier than the altis before then the new oil will get dirty faster since it is picking up all of the old deposits
    nothing to worry about though.
    It does, but then again a V8 engine has twice or more amount of oil in it compared to a 4 cylinder engine.
    Bullseye si sir Afrasay.
    Aside from those mentioned. Kung overworked or high mileage na yung vehicle blow by gasses tend to increase oxidation of oil.
    Quote Originally Posted by afrasay View Post
    yeah, the ford 4.6 trtion holds exactly 7 liters of oil. altis's 1zzfe holds 3.7 to 4 liters of oil. so almost twice nga.
    OT: 4cylinder diesels ba almost twice ang amount of oil than 4 cyl gas?
    Quote Originally Posted by 4JGtootsie View Post
    With the same displacement 4 cylinder engine, diesel may have a little more since some diesel engine have oil coolers, oil supplied turbo, piston jets and bigger oil filters. The oil pipes and size of this components stores oil therefore reducing the oil in the sump.
    thanks ramon
    Welcome bro.
    A 4.6 triton has almost the amount of oil as our trooper.
    panis sa lola ko yan, TD42 4.2 liter 6 cyclinder 11 liters of oil...sakit sa bulsa tuwing oil change.
    Dec 2007
    Pig-Rich FTW!!! :hysterical:
    sir afrasay sorry noob pero yan ba yung nasa patrol?
    Nov 2003
    2.7 liter 4 cylinder gas engine in a fortuner/innova 6 liters
    2.5-3.0 liter 4 cylinder diesel engine in fortuner/innova 7 liters
    sometimes quantity is not far apart...
Twice ba ang speed ng oxidation ng OIL sa V8 than 4 cylinders?
