I remeber this boith kast transhport show in megamall selling Redline oil products.
Anyboy knows the contact number of the official distributor of redline oil? :?:
I'm need to buy Redline MT 90 kase![]()
Thanks in advance![]()
bat nawala reply ko, ah alam ko na, sa ibang board pala yun, hehehe :mrgreen:
nasa Masangkay Street yan sa may binondo
i'll try to get you the number pag madaan ako dun.
I recalled may RedLine shop along Araneta Ave. Why not try there. Goodluck.:D
boybitz,
he he andun sa kabila he he. thankswill wait for your reply
roydok,
its not the defunct redline tuner but its a brand of synthetic oil![]()
Auto_Xer,
I just checked superhonda.com and they told me MT 90 or MTL ng redline daw pwede for honda eh :oops:
kaiinis kase dito sa pinas wala Honda MTF :cry:
What would you recommend ba for Honda trannies? I'm still worrired about motor oil being used in my tranny kase.
Originally Posted by FrankDrebin
Matagal na pong sarado yung Redline Racing.
ito po yung distributor. hinanap ko lang sa nissanbayan, i remember na nabasa ko dun dati.
Superior Motors
tel. 244-7201
1026 G. Masangkay St. Manila
how would you know which oil to use ba? Pwede ba yan sa lancer? Pano palit nito? Drain then refill lang ba? or may binabaklas pa :?:
mga around 600 daw isang bottle.
boybitz,
thanks a lot for the infoyour efforts are highly appreciated
sa honda kase I was checking out the superhonda forum and it says there that in honda trannys you could either use Honda MTF or Redline MTL/ MT 90. basta GL 4 yung rating ng Transmission oil.
I'm not sure about Lancers though :oops:
I used to use MT90 but drained it, because it shift action seemed stiffer.
Now I'm using 40 weight motor oil with MoS2 additive for it.
for yourr info lang......GL 4 rating ba kamo...isa sa gear oil ng Caltex is MTO Thuban GL 4 SAE 90pero I'm using Havoline Formula SAE 20W-50 as my gear oil kasi eto nakalagay sa Caltex Auto Lubrication Guide for M/T ng Honda Civic and Accord from '98 to '01...
bossing chief,
how bout for 99 lancer? ano pong nakasulat na pwedeng gamitin?
my previous civic logged in 120K++kms and it used 20W50 motor oil for its transmission. never had any problems so i guess its safe to use them.
logic says... if you use motor oil for your transmission fluid and you're supposed to use transmission fluid for your power steering (tama ba?) then can you use motor oil for your power steering?
post ko lang, I called up Superior Motors kanina, they are transferring to another office na daw, sa may likod na daw ng Pegasus. Their number there is 3725093. Baka by next week daw lilipat na sila dun.
