Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
    Quote Originally Posted by bxr monkey View Post
    Puwede i try,
    1. Palit air filter
    2. Linis throttle body
    3. Linis MAF sensor
    4. Check spark plugs or ignition coils
    Plus one on this. Also check din kung may butas yung mga hoses.
    #22
    in the olden days of the carburettor,
    dalawa o tatlong turnilyo lang ito, which we adjust using an ordinary screwdriver, by ear or by feel.
    i miss the days or yoric...
    Jan 2009
    #23
    Hard to diagnose engine problems when no info is provided about the vehicle.
    Modern drive-by-wire vehicles often require an idle-relearn to get the idle speed sorted out after certain types of throttle work or service. But this is often used to cure low or unstable idle speed.
    Apr 2024
    #24
    Puwede i try,
    1. Palit air filter
    3. Linis MAF sensor
    Boss done ckeaning , map sensor saken sa wall naknakakabit not on filter, napalitan n sparplug , fuel filter, ignition coil ko compact only 1, lancer gli 4g15
    #25
    Quote Originally Posted by Rjmar View Post
    how's the idling rpm upon cold start?
high idle RPM at engine start
