Results 1 to 20 of 29
    Apr 2005
    I would like to know if there are any suppliers here in the Philippines of engine scanners for OBD II compliant vehicles. I would appreciate anyone who could give me contact details.
    Salamat.
    Jan 2004
    Walang sumagot nito. May tanong ako, meron ba sa inyo (hindi mechanic or may sariling shop) na merong ganito?
    Useful ba?
    Jul 2004
    Quote Originally Posted by the_wildthing
    Useful ba?
    The scanner is very useful specially for owners of new Mercedes, BMW and other expensive cars. It diagnoses everything inside the car from the ecu, aircon, electricals etc...
    Euro cars and all German cars uses a lot of sensors that a typical japanese car does not have kaya an OBDII scanner is very important.
    Quote Originally Posted by edl100
    How about the Jap cars released here, even the newer ones? Like you mentioned, they have less sensors, but do you know if they use the OBDII standard also/already? Heard kasi, at least sa U.S., they are already fitted with OBDII.
    Jul 2004
    Quote Originally Posted by Autobeat
    Yes, I think almost all new cars now are obdII compliant.
    I think the dealership now uses the OBDII since this means more income for them. Every scan means $$$. I think they charge about P3,000 at least per diagnosis.
    Feb 2009
    Quote Originally Posted by edl100 View Post
    Clarification:
    Any scan tool even the most complicated or expensive ones is not omnipotent and DOES NOT diagnose a car's malfunction. It is merely a tool to HELP THE TECHNICIAN to diagnose a condition or malfunction. Remember, machines do not have brains, you do.
    The scan tool was not designed to replace knowledge, training, intelligence, intuition and experience of the technician. Sure anybody who has the money can buy any and all of the different scan tools but nobody can buy experience
    Sep 2006
    Mga Bossing! Meron ba kayong alam na scanner that can read or connect to a 2004 Toyota Corolla Altis 1.6 e 3ZZ-fe engine?
    I bought this V2.1 Super ELM327 Bluetooth OBD2 Scanner for Car Diagnostic Tool FAILED connection.
    and also this MS309 CAN BUS OBD2 car Code Reader EOBD OBD II Diagnostic Tool MS 309 car Code Scanner same din FAILED connection.
    Appreciate your help mga Paps!!! Salamat!!!
    Quote Originally Posted by SMPI View Post
    noon problema ko din mag basa ng toyota techstream obd protocol lalo na imv based models pero ang dami na ngayon kaya magbasa ng honda toyota nissan mitsubishi etc... in one unit. usually mga touch screen models. search ka lang sa lazada or shopee. thinktool autel foxwell etc. just be wary of the specs. i use a foxwell now
    i do find it somewhat strange na di mabasa ang 3zz-fe engine as it was also sold in different continents. yung old scanner ko could read 1NZ ng vios but not the diesel toyotas fortuner hilux innova hiace. try to see din baka may physical connection issue ka.
    It's probably not OBD2/CAN bus even though the physical connector matches. Many older cars use ISO 9141-2 protocol.
    Kingbolen wifi ELM works on the old 120. Try to edit the advanced settings w/ the custom config string shown below. Scan & gauge options should work w/ TorquePro Android app.screenshot_20230114_132511_torque.jpg20230114_150139.jpg20230115_155723.jpg
    Or....Techstream.
    Sent from my SM-S901E using Tsikot Forums mobile app
    Oct 2007
    Quote Originally Posted by the_wildthing View Post
    Useful ba?
    meron sa may d. tuazon qc. OBD2 16pin for all asian cars brand new unit and legit hardware and software not cloned copied programmed. can be updated thru internet for free. u need to register the unit first to update it.
    Jul 2004
    Quote Originally Posted by Gasoline Boy
    Salamat.
    I think there is a supplier of the LAUNCH brand obdII scanner. It is in Visayas Ave. Q.C. The place is in between Mcdo and 7-11 store. They also do training and service there.
    There is a big sign there of LAUNCH and VOLVO.
    i can supply any tools/equipment like scanners lab scopes,gas analyzers,stethoscopes etc.u name it i got it! i have access to alldata and mazda tech web.i have everything that technicians would need from made in china tools to snap-on.i am a mazda/ford technician have lots of experience in obd2 and CAN.email me at onsitemotorist*yahoo.com
    Salamat.[/quote]
    Oct 2007
    [QUOTE=Gasoline Boy;512095]I would like to know if there are any suppliers here in the Philippines of engine scanners for OBD II compliant vehicles. I would appreciate anyone who could give me contact details.
    yes i know someone. i bought a scanner from him last year and until now i do use it and very easy reliable OBDII scan tool. infact i made a lots of money doing service.
    email me if you are interested. alpha_88888*yahoo.com
    i'll give u all the info where to buy it and the programmed hardware is legit.
Engine Scanners
