Results 1 to 10 of 18
- Oct 2009
- 179
June 17th, 2015 07:57 PM #1Help mga sir. Kakakuha ko lang ng nissan sd23 pickup. Bakit ganon minsan 1 click start pero minsan kapag pinark ko then start ulit ayaw na umistart. Walang redondo, click sounds lang kada ikot ng susi. Good running naman un sasakyan. Ano to maluwag ang starter? Good naman ang battery. Thanks.
June 17th, 2015 08:05 PM #2
brad ganito gawin mo,
1. pa load test mo battery mo at alternator mo
2. pa check mo glow plugs mo kung ok lahat
3. check mo glow plug relay at control unit para sa glow plug
4. palitan mo fuel filter mo at check mo kung ok pa fuel feed pump mo.
5. check mo finally yung starter solenoid mo kung maayos pa
6. then saka mo pa check starter mo apg wala sa 1-5 ang problem.
- Oct 2009
- 179
June 17th, 2015 08:42 PM #3Nakalimutan ko pala sabihin, kapag hindi nagreredondo, nagsstart sya sa pag tinulak.
June 17th, 2015 09:22 PM #4
- Jul 2009
- 153
June 18th, 2015 01:58 PM #6
E kung ibalik mo kaya sa casa at pagawa mo sa kanila? Kakakuha mo lang may warranty yan.
Baka naman naka-engaged ang transmission o di ka nakatapak sa preno? If not baka maluwag lang ang battery terminals.
June 18th, 2015 02:30 PM #7
- Oct 2009
- 179
June 18th, 2015 02:50 PM #8Ichechecheck ko yan mga sir. So skip na ako sa heater and glow plug problems? Deretso na ako sa batt terminals and starter solenoid? Thanks.
- Oct 2009
- 179
- Oct 2009
- 2,271
June 18th, 2015 02:59 PM #10baka ibig sabihin sa display show ng mga 2ndhand unit ni TS nakuha..
natawa lang ako ng kaunti sa CASA
TS . battery yan or nasa starter.
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
