Results 1 to 10 of 17
April 13th, 2005 06:53 PM #1
Guys! Alam nyo naman ride ko di ba? 91 Sentra, ECCS, 1.6L, Automatic...
Maganda naman ang idling nasa 1000rpm, at minsan may days na ok ang takbo...pero at times, bigla nalang babagsak ang rpm! kahit nasa high speed ako, pagpalit ng gear, biglang babagsak at mamatay ang engine!
minsan naman, pag traffic, pag quick brake, pag baba ng rpm tuloy-tuloy na hanggang zero... dati na nyang sakit to, sabi, madumi ang AAC valve, i had it replaced, so naging ok na.
tapos, naulit nanaman. sabi, carbon-cleaning lang daw ng throttle body hanggang exhaust. naging okay rin for a few months, pero ngayon, ganun ulit!!
nakakatakot na kasi delikado sa daan pag biglang mamatay nalang without warning! solution ko nalang e pagnakikita ko pabagsak na ang rpm needle, e magrerev ako, (kaso pag traffic, di naman maka-abante, so neutral,brake, at rev para di mamatay..) para tuloy nagfi-feeling manual na yung kotse ko...
sabi ng mechanic ko, electrical na daw ang problem, sa ECU, kinukulang ng bigay ng power...sa casa ko na daw ipa-check...
any other opinions here??
(wala naman effect yung I-H-E setup ko dun right?)
April 13th, 2005 06:55 PM #2
just a guess, clogged fuel filter. also have ur plugs checked n sparkplug wires.
April 13th, 2005 07:04 PM #3
throttle body cleaning... isa rin yan sa pwedeng gawin...
nag pa change spark plugs & adjust a/f mixture?
your idling also is too high (it should be around 700-900 rpm). ipa tune-up mo kaya sa medyo mas reliable na shop (like speedyfix).
April 13th, 2005 08:38 PM #5
dami causes. spark fuel and air. these are the basics in diagnosing your problem. any one will cause your engine to conk out.
May 19th, 2005 05:15 PM #6
check mo alternator mo kung ayos ang karga sa battery or check the battery
May 19th, 2005 06:57 PM #9
had a similar problem b4...yng fuel filter namin ang nag-cause ng pag-patay nung makina...baka madumi yng gas or maling gas ang nalagay dyan kya ganyan...after namin palitan yng fuel filter namin naging ok na...
May 19th, 2005 07:35 PM #10Originally Posted by bobo_d_wiseman
I had the same car and same problem. Check the air sensor plug/socket, it might be loose or dirty. Spraying it with some contact cleaner will help.
Buy adhesive remover or try the Johnson's baby oil approach. See if it works for you.
Removal of Rain Visor and Chrome Door Handle and...
