Results 1 to 3 of 3
    Feb 2010
    i nid a MAF for 93 lancer GLXI itlog san po mkakabili nito mga sir surplus po at magkano po range ng price sya po ung nsa gitna ng Filterhouse at Filter Hose/Tube sabi po kc mekaniko ko sira na daw po nid na palitan ty po sa time nyo
    Oct 2009
    If these is really the problem you should see the "check engine" light on, its the orange light on the panel meter (dashboard). Your mechanic should confirm this by getting the code from the ECU or computer box. Failure of this MAF is rare for a lancer glxi 94 but it can happen. Try going to banawe
    Jul 2003
    can you describe the symptom or problem you are having with your engine? or is the MAF sensing wire broken at all?
Help MAF for lancer 93 GLXI itlog
