Results 1 to 10 of 13
- Mar 2009
- 64
November 9th, 2009 12:38 PM #1Sir yung dina-drive ko na '95 Corolla gli Automatic kapag
naka neutral biglang namamatay un makina. Pero start naman
agad kapag on ko. Kapag naka Drive naman kapag bumababa yung
RPM nasa 100 kapag di ako umaandar pero di namamatay. Biglang bagsak talaga.This happens after 20mins of driving.
Dinala ko sa Speedyfix kanina di tuloy nila makita na bumaba ang RPM kasi nga this happens after driving that long. Balik ko na nga lang after more observations.
So after reading some threads here, alin po ang dapat na ipacheck ko:
1. Belt tension
2. Air Hoses connecting the alternator or may singaw sa air hoses
3. Throttle position sensor
4. Thermostat
5. Vacuum switch
6. Servo? ano ba yung Servo?
7. Throttle body or IACV? ano yung IACV?
I need your help. I'm worried. Thank you very much po!A
November 9th, 2009 02:32 PM #2
Kailangan lang palinis ang Thottle body , Mass air flow sensor, Idle air control Valve kadalasan problema sa idling .
November 9th, 2009 02:41 PM #3
may MAF ba yung 95 Corolla? Feeling ko rin kahit linisin throttle body, parang hindi rin, kasi after a certain period of time pa naghihingalo. anyway, sorry, hindi rin kasi ako marunong sa carb engines hehe.
palinis muna distributor lalo na kung na-ondoy si corolla mo TS.
November 9th, 2009 02:45 PM #4
- Sep 2007
- 215
November 9th, 2009 03:52 PM #5
may pinalitan ka ba sa car mo ?
tama nga baka madumi lang yung trottle mo malinis mo ... try starting your car without the aircon ... baka lang nag hi-high pressure lang yun compressor mo kaya bumababa yung idling mo ..... kung ganun pa rin sa trottle na problem mo pa check mo sa mechanic to clean and adjust
regy
banawe auto supply
7120115
- Mar 2009
- 64
November 9th, 2009 09:20 PM #6Sir thank you sa reply sige sabihin ko na lang po sa speedyfix!
EFI po yung Corolla. Hindi naman po na-ondoy si Corolla muntik lang.
thank you sir sa reply!
yes sir salamat po!
Sir salamat po sa reply! I'll observe nga po kung ganun pa din ang situation if walang air-con.
November 10th, 2009 09:18 AM #7
- Mar 2009
- 64
November 10th, 2009 12:36 PM #8Mga Sir, guess what after posting this thread yesterday, kinagabihan hindi ko na po ma-start yung sasakyan. Walang reaction talaga whatsoever.
Pina-check ko po yung battery na-diskarga, pinapa-charge ko na ngayon.
Related kaya yung malapit nang madiskargang baterya sa naging problema ko sa RPM? Papacheck ko din yung alternator.
- Mar 2009
- 64
November 10th, 2009 05:06 PM #9Mga Sir OK po yung accelerator.
Pero hindi nga daw related yung problema ko sa RPM sa accelerator
at baterya. Medyo luma na yung battery na de tubig ko estimate ko mga 2 years na sabi nila bili na daw ako bago kasi nagpaparamdam na daw yung baterya.
Damay daw kasi lahat ng electrical kung luma na battery. Palitan ko na din daw yung mga wiring.
Ok po ba yung advice ng electrician? Thank you po!
November 11th, 2009 08:34 PM #10
imho, hindi damay yung lahat ng electrical kung luma ang battery. hindi din dapat palitan kaagad yung wiring....
mukhang niloloko ka nung electrician bro... dapat full diagnosis ang electricals bago rewire. although yung battery mo which is 2 years, is ubra pa yan. imho, dapat hindi pa nagloloko yan.
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
