Results 1 to 10 of 21
    Jul 2006
    Quote Originally Posted by 4JGtootsie View Post
    Aside from the the fuel consumption, how about noise, smoke, temp, power and response?
    sa noise,smoke, temp wala...pero power slight and medyo mabagal ang response.
    Jul 2006
    up po.....
    Jan 2008
    Baka low pressure yung gulong mo, o di maganda ang quality ng fuel mo, o madumi lang ang fuel injectors. Pwede ring yung brake mo sumasabit.
    Nov 2003
    let it relearn then measure again in a week or 2 siguro. aside from that kung tama yung kabit there should be no effect.
    May 2010
    Mga Sir's... Im a newbie here at tsikot and Im glad to get info's on how to maintain a car, may problem lng po ako about my 89 corolla small body which is my 1st car it has a 12valve 1500 engine, I've had made major replacements on it already but one thing that really bother's me is the FC which is only 5.6kml/ i compute the consumption by getting the litters that i have poured in and dividing it to kilometers that i have runned, ends up I only run 5.6km/and sometimes its less, I already had it tunned up even twice even had it re-jetted to a smaller jetts had the timing setup as normal as it should I've changed my oil filter/air filter even the spark-plugs and its burn which is flesh/ the idle was okay basically I had it tuned up just fine but I'm still consuming too much fuel, I think this is not the right thread for me to go to, but it seems like the people in this forum are the same folks that I seen in most of the forums that I have visited, at least at 40 forums.,
    Any advise will be greatly appreciated
    Thank you!.
    There are so many factors affecting fuel consumption, let me ask you the following questions muna:
    1. What major changes did you make/replace on the car?
    2. Did you zero the trip meter, fill-up the tank, ran the car a certain number of kilometers, fill-it up agan, and divide the trip meter reading versus the fuel consumed per gasoline refilled to obtain the FC reading?
    3. Where and how long have you been going to this mechanic, and did you inform him of your predicament?
    4. Any unusual things happening to your car (say rough idling, blue/black/white smoke)?
    5. Any racing related equipment set-up in your car (headers, scavs, etc)?
    May 2010
    Thanks sa reply..
    na ffigure out ko ung consumption usage nya every time na nag ggas ak say 7 liters then i usually reset the odometer ang basis ko is ung last line sa gauge actually ni re-jet na un ng mechanic ko pero parang ganon parin ehh 400 worth of gas only runs for 30kms, do you think I have to bring my car to kamuning and have a carb overhaul?
help! FC tumaas
