Results 1 to 10 of 21
September 4th, 2008 12:32 PM #1
tumaas po ang fc ko after replacing timing belt.ano po ang problema?
September 5th, 2008 07:41 AM #2
baka naman it is skipping a tooth. unlikely, but the only explanation I can think of...
replacing timing belt lang ba ang pinagawa mo?
September 5th, 2008 10:04 AM #3
Kung palit lang ng timing belt. I would suggest to tune up your car also and re-time the timing.
September 5th, 2008 11:29 AM #4
Have them check that they replaced everything properly... do you experience a loss of power? Having the belt off one tooth will negatively affect performance and fuel consumption .
Tsikot Member Rank 5
- Nov 2003
- 3,848
September 7th, 2008 05:22 PM #5yeah, it shouldn't be affected by the timing belt unless it was incorrectly installed.
September 8th, 2008 06:26 PM #7
September 9th, 2008 08:00 AM #8
September 9th, 2008 08:48 AM #10
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
