Results 1 to 10 of 10
    Help me mga masters. My 2008 Toyota Avanza J seems to have an idling problem. The RPM goes up and down when the A/C is on and there is a clicking relay sound. This only happens when on full stop with A/C on. Youtube video below:
    parang nangyayari yan pag nag eengage yung compressor ah...
    siguro best thing you can do is to have your compressor and its related electricals checked.
    Sep 2005
    masyado ngang magalaw.. pa check nyo sir aircon..
    Jul 2006
    Did you have AC work done? Your AC circuit is experiencing hi-pressure. Kaya erratic on-off yung compressor.
    Sep 2006
    Sir pacheck mo yun sensor sa throttle yun apat yun wire yan kasi ang nag control sa idling
    Salamat mga paps. Any more inputs? By the way, nawala symptoms kanina. So mukhang intermittent.
    oo nga.. baka barado ang aircon tubings..
    pa-check na rin yung pressure sensor ng aircon/freon ... madali lang naman i-test ito ng aircon mechanic
    Feb 2025
    Quote Originally Posted by hcdangan View Post
    Same for my 2013 Avanza E now. Did you ever find the problem?
    From comments in the youtube video someone cleaned his servo (IACV) with carb cleaner and fixed it.
    So I guess the real problem was a blocked or failing IACV.
HELP: '08 Avanza J idling problems--RPM rises and drops
