Results 1 to 12 of 12
    mga bossing, car ko po ay corolla xe, the problem is hindi na gumagana ang plunger para sa idle ng aircon kaya kung bukas ang aircon, ang baba ng idle and pag ng-automatic naman ay wild ang idle.
    my querry is magkanu po ba ang surplus na carburador and kung may repair kit, magkanu po and saan nakakabili? and lastly, pwede po ba carburador ng 4k sa 2e? salamat po sa inyo!!!
    Apr 2005
    bro dalhin mo na lang sa kamuning. kay mando ng A&M carb specialist.
    I don't think sa carb ang problema mo, pag nagmemenor yan walang problema yan. Ang problema mo ung sa idle up vacuum. sa aircon repair mo dalhin.
    [SIZE=4]Tama si Reym, hindi carburador problema mo.
    Yung "idle up vacuum" ang me sira, not the carburetor.
    Yung "idle up vacuum" ang device to maintain a constant idling rpm in the event na sumipa ang load ng compressor or other load sa makina.
    Dalin mo lang sa trusted mechanic mo. Baka yung linya lang me dumi or what.
    [/SIZE]
    Feb 2009
    Quote Originally Posted by odrag View Post
    odrag,
    your engine is way too small for your car as designed for the asian market, this is the reason why the idle speed drops with the additional airconditioning load to the engine and the electrical system when the compressor clutch and condenser fans kick in. to compensate this, the fuel control either raises the idle speed by the use of a vacuum throttle kicker or an idle up solenoid to open the throttle plate higher than idle speed (carbureted engine like what you have). this solenoid throttle kicker is in parallel circuit with the compressor clutch.
    jick
    mga bossing, thanks with all the inputs! hindi nga carb ang problem, the culprit is my "idle-up plunger". ng-bara po yung butas kaya di humihigop, nalinis ko na and nagpalit din ako accuator. working na po, meaning nag-lalaro na po yung mechanism attatched to it kaya lang baligtad pa rin ang idle, bumabagsak kung bukas aircon and wild ang idle kung ng-automatic na. ano pa kaya ang problema? pasensya na po pero sana matulungan nyo pa ako...
    bro adjust mo idle up adjusting screw habang nakabukas aircon para makuha mo ang tamang idle.. at palitan mo ang vacuum hose baka may bara na hindi mo natanggal o kaya lumiit na ang butas ng hose mo.. hindi kasi pwede kapag maliit ang butas talagang magwawild yan..
    Alin d2 ang hindi gumagana? Ung isa sa 2 bilog?http://cens.com/cens/supplier/16337/.../54211/BIG.jpg Alam ko pede yan, pero tingnan mo muna mabuti baka same problem lang ang abutin mo, kc normal sa 4k carb na luma ala na provision para sa aircon.
    I suggest check mo muna mabuti, kung ung 2 ang sira nakakabili sa surplusan nun.
    Check mo kung kasya ung 4k sa slot, pag kasya pwede.
    Jun 2014
    Yung car ko is oldlook 91, yung carb nya ay pang 4k engine na nung mabili ko. Problem is walang idle up para sa aircon kaya pag nag aircon ako bumababa ang RPM. Ginagawa ko tinataas ko ng konti para pag ang aircon ok pa rin. Good thing is matipid sya sa gas pag naka AC at magastos pag off ang AC. Bagong bago yung carb ko pa pang 4k. I've heard na yung mga luma walang sabitan ng AC idle up pero yung sa kin wala rin.
    Meron bang nabibili or nakoconvert na AC idle up para magfit sa 4k na carb? Sana may sumagot sa tanung ko mga bros.
    Quote Originally Posted by reym View Post
    Sep 2019
    Sorry for bumping this old thread,
    I had to since I am unable to start my own thread yet.
    so I have a Ae92 corolla small body with a 2e engine, yong problema po sira na ang carborator, so bumili ako sa Lazada ng 4k carborator kasi sabi ng seller na pwede lang, tapos nong dinala ko sa mekaniko po, sinabehan ako na wala daw idling sa aircon,,
    pwede po pa advice mga sir,
    AE92 toyota corlla, small body, 1989, 2e engine po pala
    Dec 2019
    Quote Originally Posted by babor038 View Post
    Tol, paano ma nalaman na sira yung carb? tanong lang.
    Bro, pareho tayo ng naging problema. small body din kotse ko, 1992 model. Ang carb nyan Aisan orig. Parang naisahan ka sa pagbili agad ng carb kagaya ng nangyari sa akin, kaya ayun may spare ako na carb, pero pang 16-valve.
    Try mo dalhin sa Evangelista yung orig na carb, sa tapat ng INC church hanapin mo doon si Alvin o Arnel. Malupit sa carb, yun ang specialty nila. Medyo me kamahalan nga lang pero magaling talaga. Dati, dinadala ko taun-taon sa QC (hwag na tayong mag-name drop) yung kotse ko para ipaservice yung carb. HIndi naman pala kelangan, maintenance lang kapag naitono na talaga. Hope this helps.
    Dec 2019
    hi, odrag. ganyan din ang naging problema ko. try going to Evangelista street, sa may tapat ng INK church may carburetor specialist doon. Hanapin mo si Arnel o Alvin. Medyo mahal sila sumingil pero matino gumawa. Yung 92 corolla ko ganyan ang problem. Naayos, naging fuel efficient pa. Hope this helps.
carburetor problem
