Ano ba problema pag hard starting sa umaga ang sasakyan? pero pagstart tuloy tuloy naman. Lalo na kung malamig panahon. Injection o makina?
check that all your glowplugs are in working order. Bunutin isa isa and recta sa battery. The tip should smoke after a second. pag hindi nag smoulder, malamang defective.
hope this helps... goodluck!
Yep, that's the first thing you check, yung glow plugs. Ano na odometer reading mo?
If they are defective, make sure you change all of them, huwag yung isa-isa...
Kakapalit ko lang kasi yesterday. Same problem na medyo weird ang pag-start sa umaga..![]()
Bakit kaya yung MB100 namin ang lakas sumira ng glow plugs? Mukhang sira na naman. Hay...
otep::: Di kaya theres something wrong with the relay which feeds the plugs. Baka longer than intended yung bigay ng kuryente?
