Results 1 to 10 of 21
- Oct 2009
- 179
September 1st, 2017 11:37 PM #1Helo mga sirs. Hirao start ng sasakyan ko. Efi. Nagpalit na ako fuel pump, linis gas tank, palit fuel filter. Everytime na start ko kailangan pa ichoke sa throttle body then pag matagal ng nagamit then off then on 1 click naman pero pag kinabukasan ko na start ganun ulit kailangan ulit takpan un throttle body para umistart. Ok un maf sensor kapag hinuhugot ko un socket namamatay engine. Ano at saan kaya ang problem? Thanks.
September 2nd, 2017 12:19 AM #2
how old is the battery?
- May 2011
- 481
September 2nd, 2017 05:15 AM #3
- Oct 2009
- 179
- Oct 2009
- 179
September 2nd, 2017 06:15 AM #5
- May 2011
- 481
September 2nd, 2017 08:20 AM #6
- May 2017
- 572
July 5th, 2018 12:56 PM #7So many existing threads about hard starting so will just revive this one.
I have a 1999 Pajero Fieldmaster. Battery was newly replaced. Alternator not so new but tested ok naman. Every morning when i start the engine, it goes with one click... then the engine warms up. Problem is after 30 seconds to a minute, the engine starts "coughing" or "dying" matched with some spurts of smoke from the exhaust and eventually dies.
When i try to restart it... it won't na unless i step on the gas pedal and pump. Tapos when it finally starts, you would really need to pump the gas pedal repeatedly (smoke keeps on coming out of the exhaust) to keep it going until it can run smoothly on its own.
This only happens in the morning upon starting it after a long rest. The rest of the day, this won't happen again.
Any thoughts? Thanks!
- Jan 2008
- 4,726
- Aug 2013
- 475
July 5th, 2018 02:40 PM #10
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
