Results 1 to 6 of 6
    mga sir,
    I recently acquired an engine for my nissan maxima, as newbie, I do not know much on what papers should have come along with it.
    What I got was just the OR/CR, plus written documentation ng bentahan namin.
    Problem:
    1. As per LTO, kailangan ko ng Official Receipt ng pagkakabili ng makina, ang kaso tao-tao lang pagkakabili ko nung Engine, not through local surplus shops, pano ito?
    2. Wala na dito sa Philippines yung napagbilhan ko, ang nandito na lang is yung nag-refer (middle-man).
    Pano ako ngayon makapag pa-change Engine?
    TIA
    see response below. the engine documentation is important for it will be the basis of your engine change.
    without that, using all proper and legal channels, it can be really hard. but then again, kung may kakilala ka sa LTO, magagawaan ng paraan yan.
    Quote Originally Posted by CoolSwitch View Post
    mga sir,
    Problem:
    - pero even though tao tao dapat may proper documents yung engine, imho.
    - go back to the middle man and ask him if he can produce some documentations.
    TIA
    Quote Originally Posted by 1D4LV View Post
    ang hawak ko is OR/CR nung car na pinanggalingan nung makina, previous deed of sale nung car between 1st and 2nd owner.
    sa OR/CR name pa rin ng first owner ang naka-reflect.
    what specific documentation should I be looking for?
    Jan 2014
    sir i know na matagal na ito, pero can u please share kung ano ang nangyari sa problema mong ito? just to get some ideas from it....TIA
    Jan 2011
    you dont need OR from surplus shop anymore, all you need is the CR and OR where the number of engine is reflected. sufficient na yong deed of sale ng engine. ang gawin mo nalang dyan, macro etch sa PNP crime lab para mabago na ang entry doon sa OR at CR ng sasakyan mo. bali ngayon kasi, 2 sets ng OR/CR ang hawak mo, isa doon sa makina at isa sa sasakyan mo. pag isahin na po yan sa isang CR/OR lang. hope this helps.
    Jan 2014
    Quote Originally Posted by shelu View Post
    As of now sir ung situation ng sa akin ay ganito, first wala pa sa akin yung surplus engine na ipapalit ko sa existing (it will come end of the month fresh from japan) may nagsabi sa akin na kelangan maiapply ko muna sa HPG ang change engine notification bago ko pa ipabaklas ang existing or else magkakaroon ng problem ako. Isa requirements ng change engine application ay notario para sa change engine duly signed ng owner, ang hawak namin ay deed of sale lang (open) pwede ba yun sa notaryo? or kelangan talaga ipa transfer muna namin ang registration sa mismong name namin. 2ndly ung engine after mag arrive sa pinas 2-3months daw bago mag available ang engine registration sa LTO (anyway sabi nila ok lang daw ito, pag renewal ng rehistro ng car dun ko na lang daw i-attached para deretso mailagay na sa bagong OR/CR)......anong masasabi mo base sa experience mo or any other tsikoters....TIA
Change Engine Procedure
