Results 1 to 18 of 18
    Aug 2009
    Anybody here from Angeles pampanga knows a shop who do CO2 testing for the right Air/Fuel mixture ratio in a car? This CO2 tester will tell you if you are running lean or rich in fuel. Thank you.
    Feb 2009
    Quote Originally Posted by BJ71 View Post
    exhaust gas analyzers nowadays do the five gas analysis: CO,CO2, HC, O2 and oxides of nitrogen. to properly analyze the exhaust emissions, most states use the five gas analyses just like california specs. obd II systems are already capable of doing this
    Aug 2004
    The problem with engine tuning with an exhaust gas analyzer is that it might not have a quick enough sampling rate to allow you to do fine tuning.
    You need an AF-Meter with a wideband O2 sensor... not a CO2 sensor... to tune your air-fuel ratios.
    Feb 2009
    change your analyzer
    Oct 2009
    Since most automotive shops in the philippines does not have a exhaust gas analyzer, try going to a smoke emission test center, the one we used to go when we renew our vehicle registration.
    Aug 2004
    Forget the emissions center, take your car to a performance shop with a wideband. Most emissions centers only have readouts for HC, CO and particulate emissions. While you might be able to tell if the car is running incredibly rich from the HC readings, you won't have the tuneability you'll get with an O2 sensor.
    Yes, a modern five-gas analyzer will do O2 also... but local emissions centers are only required to measure HC and CO. Nobody does NOx or O2 testing at the smoke places.
    Just curious sir, doesn't the ECU self-adjust the air-fuel ratio depending on the readings from the onboard sensors? TIA.
    Aug 2004
    Depends. If it's an OBDII car with oxygen sensors, yes. Some OBDI cars, too. But some 90's cars with OBDI that came here had the O2 sensors disconnected or simply not put in.
    *niky - thanks for the reply sir, one more thing... Would using e10 (which I read is a gas oxygenator) increase the oxygen in the exhaust and "fool" the oxygen sensor into thinking that the engine was running lean and cause the ecu to make the A-F ratio richer?
    Aug 2009
    Hi sir niky, What performance shop do you recommend here in manila?
CO2 tester: for Air/Fuel mixture
