Results 1 to 6 of 6
    Apr 2011
    Nag didip yun idle after matanggal and kabit ulit ang battery. Nag search ako about sa "idle re-learn" kaso puro sa automatic lang. Car is toyota innova '05 manual. thanks!
    Jun 2005
    Quote Originally Posted by sn0wbLind View Post
    Normal yan. Just use the car a few kilometers. Babalik sa dati yan
    Sent from my MI MAX 2 using Tapatalk
    Apr 2011
    Quote Originally Posted by sirkosero View Post
    Copy! thanks!
    Jul 2019
    I think nag charge yung alternator sa battery mo kaya mag drop ang idle. Pero normal lang ito.
    Sep 2005
    ihataw mo lang sa highway.. mag auto re-learn na yan...
    Bro.,- if you have a voltmeter,- check the voltage while the engine is running,- ideally should be a healthy 13.8V even when the accessories are engaged (head/park lights, aircon etc),- but should not be near 12V.
    Just a rough reference on the voltage of the car battery
low idle after removing battery
