Results 1 to 5 of 5
    May 2005
    I had a problem with my idling where it always goes to 1500 RPM pag nka stop. I adjusted my idling but unfortunately, it stays at the same reading. I just had my Carburetor overhauled this Saturday in Kamuning as recommended by one of our mechanics. The result was overwhelming. My normal idling is 900RPM. If I am cruising and step on the gas, my idling goes to 2000 RPM tapos pag ni-release ko yung gas, babalik sya sa 900 RPM.
    However, ngayong umaga, napansin ko na bumalik na naman yung problem. Ayoko munang iadjust yung idling.
    Balak kong ibalik sa Kamuning yung sasakyan tomorrow. I just want to ask inputs from you guys on what you think the problem is.
    Feb 2003
    check mo yung tension nang accelerator cable mo... or baka kailangan na palitan din...
    adjustment lang siguro, balik mo agad sa kamuning, nangyari din sakin yung pagkaoverhaul nila ok pero the following day na-iba agad yung idling, nung binalik ko inadjust ulit then ok na...
    May 2005
    Guys,
    I solved the problem. Yung spring na nagbabalik sa default position nung Carb ang culprit. Pag nag rev ka, nde na sya babalik sa dating pwesto nya kasi mahina na yung spring. Napalitan ko na kahapon at oks na sya ngayon.
    Phew, thought problema na naman yung carb.
    Thanks guys.
    Apr 2005
    Quote Originally Posted by goldencoil
    Guys,
    Thanks guys.
    pre, where did you buy the spring? yung corolla ko kasi ganyan din. tagal naman balik spring to normal. pagtapak mo, bagal balik. tia!
Help!!! Mataas na idling
