Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Jan 2012
    can anyone give some advice/info regarding this. curious lang po... TIA
    Quote Originally Posted by Kasenklaud View Post
    It's only for carburetors. Not applicable for EFIs. Kaya to ginagawa sa karburador para yung next start mo madali na.
    Oct 2011
    akala ko para mawala ang carbon.
    Sabi ng tatay ko dati para macharge daw battery. Hahaha. Lokong tatay.
    Sent from my Nexus 7 using Tapatalk HD
    Jun 2011
    yung office mate ko, hardstarting sa umaga, i advise her to rev. it before shutting it down... as in naka gas pa before turning the engine off...
    he..he.. effective, one click nalang ngayon..
    sarap kasi pakinggan yung vroom vroom sabay patay ng ignition
    para kang naka sports car
    Sabi rin ng Tatay ko, para raw masigurong hindi barado ang karburador. Kasi pupugak- pugak daw 'pag may bara.
    No need, even with carburetor rides. It's just a waste of gas and add-on to pollution. We have a carb 93 Sentra at home and even with it's current lousy tune, it still starts one-click in the morning. No revving at all.
    If you're 79 yr old then you can do it. Mga lumang Tao lang gumagawa niyang
    Sent from my iPhone using Tapatalk 2
    Oct 2011
    hindi na uso reving ngayon, idle lang for seconds and then turn-off engine.
    Sep 2008
    myth eto. if you rev the engine then switch off. What happens is unburn fuel will remove the oil film in the cylinders. Hence, the next time you start, you will have more wear on the cylinders. You will see more ridge once you have the engine.
    Sama na natin yun Gawain ng mga lumang tao, yun kabaligtaran naman nito na "nagpapainit" ng engine sa umaga...
    Sent from my iPad using Tapatalk 2
    Oct 2009
    para daw magkaroon ng laman ulit ung carburador..saka para daw umakyat ung langis..
    i have a colleague that's still doing this thing on his 10th gen corolla. kaya alam na agad kung dumating na sya. hehe! kakahiya lang sabihan na old style na yun ginagawa nya.
    Jul 2010
    Mura pa kasi "fuel" noon unang panahon.
    Sep 2012
    Ang alam ko sa iba gusto lang daw nila marinig yung maingay nilang tambucho vroom vroom vroom vroom
    Oct 2011
    para daw umalis ang evil spirits.
    Old or new car are just waste of fuel. But for those with turbocharge, read your owner's manual carefully, 'cause doing so might and probably will damage your turbocharger, BEWARE!
    Oct 2011
    paano ma damage ung turbo charger sir? ang sabi sa manual after a long speed drive (2hours) don't turn-off your engine immediately idle muna 3-5mins. eh 1 sec. rev lang naman ito.
    The reason you leave the engine on idle is to let the turbo spin down, if you rev your engine before turning it off, it might cause the turbo to spin again.
Revving the car before shutting off
