Results 1 to 4 of 4
    guys...need your help, ask ko lng kung saan nakakabit yung sensor ng fuel filter?..my engine is 4d56
    did you try checking the lower part or the upper part of the fuel filter (yung may pump)? if its not there, baka dun sa water fuel filter niya (usually located under the vehicle, near the gas tank). its a filter with a wire...
    The wire for the sensor emerges from underneath the filter body.
    The connector is an idiot-proof connector. It will not mate with the wrong connector.
    On the Pajero, the connector it mates with is mounted on the firewall near the driver's side. Don't know if this is also the case with other 4d56 vehicles. Just look for a dangling connector that is a match with the connector on the base of your fuel filter.
    ok guys.. ill check it.. tanx
fuel filter sensor
