Results 1 to 20 of 20
    Jul 2013
    sir mam meron po ba gumagamit nang diesel sa pag engine flash i mean pag change oil po pano po ba ito ginagawa
    tia
    Aug 2010
    i saw one mechanic put diesel in coke 1 liter bottle that serve as tank for gun spray (compressor). gaya ng ginagamit ng mga pintor. after draining the oil, spray the engine with diesel, ma flash na yung oil.
    Jun 2010
    pag gas powered ang engine mo mas ok gumamit ka na lang ng diesel oil for a week or two then change oil ulit, mataas kasi ang detergent ng diesel oil, ganyan ginawa ko on both of my cars after ko mabili 2nd hand, effective for me kasi wala kang makikitang sludge sa rocker arms assembly after ko mag palit ng VC gasket...
    Jul 2013
    sir diesel engine po pag gagamitan ko pano po ba sabi kasi ng iba sakin drain ng 1liter tapos add ng 1liter na diesel paandarin tapos drain tama po ba
    Re. using diesel fuel as an engine flush, I remember lowslowbenz explaining this before... have to dig it out though.
    If you change oil regularly though, there is no need to flush.
    May 2008
    Unfortunately, if your engine already has sludge, the only way to remove it completely is to manually clean it by opening up the engine aka ovehaul. Other than that you run the risk of clogging the internal oil paths in the engine by the sudden release of all that gunk.
    If you’re not willing to do that then may I suggest the procedure which I used in my vehicle with some alterations. Get a good oil with good detergency. In my case, I used Top 1 SDO and Mag 1 All Fleet. Then shorten the interval of change oil to 1,000 then 2,500. After that I used a good and tested engine cleaning oil additive. I used seafoam. But I heard that Autorx is also good. Then change oil 1,000 and 2,500 and 5,000 intervals. After completing it, make sure to have your oil pan and oil strainer (if your car is equipped with one) cleaned. You can also add 2t to your fuel to clean your injectors and fuel lines.
    Jul 2006
    I use diesel fuel to flush old oil and sludge out (if there are any). I buy a gallon of diesel, drain the old oil, and load in the diesel. Do not remove the old oil filter just yet. Determine that the diesel inside your engine has reached (at least) the minimum level on your oil dipstick. Then let it idle for around 15 mins or so, para umikot ang diesel sa oil galleries, DO NOT REV!
    Drain overnight, and remove your old oil filter. Kinabukasan, pour in fresh oil, and screw in a new filter.
    Disclaimer: This is what I do, as part of good maintenance habits. You may, or you may not opt to do this procedure, for whatever reason.
    i don't use engine flush. what for?
    Aug 2010
    Quote Originally Posted by raycon_24 View Post
    a week or two?
    Mar 2013
    ganyan din ginawa ko kay lowslowbenz pero yung sludge talaga sa valves parang aspalto na ewan ko lang sa oil pan kung ano itsura wala pa akong torque wrench set para buksan 13t engine
    Oct 2013
    This works for gas engine and diesel engine? Thanks!
    Sent from my LG-D802 using Tsikot Forums Mobile App mobile app
    Beep Beep! School Bus! Beep Beep! School Bus!
engine flash using diesel
