Results 1 to 8 of 8
    Mar 2013
    Patulong naman po sa Lancer pizza 2001 A/T.
    Pag nagaaccelerate po ako, minsan biglang magddrop rpm na parang bigla mong binitawan yung gas pedal kahit tapak ko naman, mas halata siya sa low speed at low rpm kasi kumakadyot tuwing bababa yung rpm. Nangyayari din sa high speed high rpm pero di masyado ramdam kasi di na masyado kumakadyot, mapapansin mo lang kasi nawawalan ng hatak habang nakagas ka. Yung pagbagsak pala niya sandali lang, parang 1sec. lang na babagsak tapos balik normal na ulit.
    Di naman po nakailaw yung check engine, yung oil o yung battery na indicator.
    Newly changed oil po pala at changed atf at linis ng EGR at newly changed spark plugs at isang coil, di ko pa napalitan yung coil kasi out of stock sa pinagbibilan ko.
    Di ko na alam kung anong problema eh, kala ko mawawala pagkachange ATF ko, kaso wala, nandyan parin.
    Sana may makatulong. Salamat!
    Jul 2011
    Try mo magpa gas sa iba, baka contaminated ung fuel
    Mar 2013
    Quote Originally Posted by Manilablock View Post
    Thanks sir,try ko pa gas sa ibang gas station next time
    Quote Originally Posted by haxso View Post
    when was the last time you changed your fuel filter?
    Mar 2013
    Around 1 1/2 to 2years ago po sir
    you may want to change it and try to gas up in other stations.
    Mar 2013
    Will try that sir..sana yan na nga sagot sa prob ko..thanks!
    Sent from my SM-G920F using Tapatalk
    Mar 2013
    Ok na po,kulang po pala yung nailagay na atf nung nagpapalit ako ng atf, siguro kulang na talaga siya bago pa ko nagpachange ng atf..buti naisipan pacheck sakin nung naglagay..maraming salamat mga sir!
Erratic RPM drops while accelerating
