Results 1 to 13 of 13
    Oct 2004
    mga boss...
    paano po linisin ang air filter ng apexi? wala daw nabibili na cleaner ang apexi not like knn may cleaner and oil nabibili...
    ok ba gamitin ko pang clean ng apexi air filter ay K&n cleaner product ty thanks for your advices
    Sep 2005
    Maintenance free ang apexi bro.!
    Oct 2004
    ah pano kung maitim na?
    you can use the cleaning kit sold for K&N.
    tanong lang po, sa pinas po ba yung Apexi nabili? ang alam ko kasi, sa ngayon, wala pang nagbebenta ng Apexi dito...
    Nov 2003
    if it's maintenance free then don't clean it na... just rinse it off or use compressed air. if it's paper like k&n then you can use the k&n cleaning kit.
    Nov 2003
    Oct 2004
    ok thanks sir migs
    Quote Originally Posted by rion View Post
    Sa ngayon po wala pa nagbebenta ng apexi filter.
    By order lang, import from US, usually 1-1.5 mos bago dumating.
    Quote Originally Posted by bryant77 View Post
    I see, thanks.
    Jul 2006
    Get a compressor blow it out from inside. That usually helps. If it's paper type filter try to avoid the cleaning solution.
    Aug 2004
    It's dry-type... don't oil it!. Just do as mbeige says... use compressed air to blow the dust out of it from the inside.
    Oct 2004
    yup its by order...
    to all thanks for the infos
need advice for apexi air filter
