Results 1 to 9 of 9
    I'm gonna buy a new engine for my honda city. meron nagbebenta sa akin ng d15. based on my latest research, marami palang variant ang d15:
    D15B 130 hp SOHC VTEC-D15B (eto sana gusto ko)
    D15B 105 hp SOHC non-VTEC (eto ata yung stock ng city 1.5 ko)
    D15Z 115 hp SOHC VTEC-E (ok din sana to. totoo ba 20+ km/l ito? eto ba yung stock ng city type z na 1.5?)
    How do i know just by looking at the engine kung anong variant ng D15 yung tinitignan ko. thanks!
    any other suggestions on where I can buy the 130hp d15b?
    yung non vtec variant has a slightly smaller head cover.
    Yung vtecs, im not sure.
    Why not put an EF B16A instead?
    yung 130hp "D15B" ang engine code na makikita mo sa engine block
    eto yung JDM d15B and with a single solenoid
    yung d15b nakalagay sa city 1.5 i think PH15 ang engine code nito
    correct me if im wrong...
    yung 3 stage naman wala kang makikitang VTEC sa valve cover
    mapapansin mo lang dalawa yung soneloid nya...
    get the D15B JDM....130hp kung maka tsamba ka pa sana makuha mo
    yung with LSD na...
    kung ok lang sa iyo na meron minor welding na gagawin sa engine mount
    mag b16a ef ka na ....
  4. kevin Guest
    Quote Originally Posted by ozcity
    yung with LSD na...
    bad trip! sira yung forum pag naka-login ako as kevinp. pano ba ayusin to?
    oz, para sa ermat ko kasi yung city. nasira engine kaya bili ng bago. its more out of necessity rather than upgrading the engine for racing or drag.
    ala ako masyado alam sa engines e. ano yung solenoid? ano itsura? yung 3-stage ba na sinasabi mo yung 115hp version?
    kevin,
    register ka sa Honda Club forum and check oput the tech forum dun. meron dun posts dealing with the D15 engines
    Http://www.hondaclub.com.ph
    si Ozcity kasama sya dun! meron thread ng City opwners din dun sa mainforum
    Dec 2002
    mmmmmm... may I ask what happened?
    curious lang ako, since city is not that old para masira yung engine.
    Kung daily use siya and maintainlang as you've said, I suggest you get an engine same as the local 1, so you won't have any problems w/ parts sourcing
    hehe. ermats gumagamit. di namalayan na 1 year na pala di napa-change oil. ayun, namuo ang oil sa engine block.
    Apr 2008
    yun sinasabi mong D15b na 130 horsepower yan ay galing sa JDM civic-Eg1 and 4 at sa lahat ng stock engine na D15b yan ang pinaka malakas..... puedeng puede yan sa city mo... well dipende yan sa gusto mo, kung gusto mo na mas malakas pa dyan go ka sa B series ng honda engine gaya ng B16A or higher pa dyan kung mag B16A ka mas maige na yun kunin mo galing na mismo sa EG para mas modelo ang problema nga lang basta B series na honda engine hindi ka bababa sa 75k
    Oct 2007
    D15b vtec 130hp JDM...yan na kunin mo bro...mas lalakas pa yan kung lalagyan mo pa ng add ons like IHE..
D15 engine question
