Results 1 to 4 of 4
- Jul 2005
- 22
September 2nd, 2006 10:51 PM #1Tanong lang po.. saan ba ang engine support located sa mitsu adventure? at pano malalaman if ok paba o medyo sira na engine support mo... kasi notice ko lately parang malakas ng nginig sa engine, when my idle speed seems to be fine.. could it be the engine support. need you help... thanks..
September 2nd, 2006 11:18 PM #2
September 3rd, 2006 10:16 AM #3
for auto trans only. ganito gawin mo (you need a helper to this). engage the parking brake, step on the brake pedal hard enough to prevent the car from moving, then put the car in drive then step on the gas harder and look sa engine, pag excessive ang tilt ng makina the support ay sira na. para sa other side naman, same procedure only engage naman trans sa reverese.
Tsikot Member Rank 5
- Nov 2003
- 3,848
September 3rd, 2006 10:30 PM #4you should have around 4 engine supports... have it brought to a shop to check if may sira isa or more than one dun.
Couldn't have explained it better myself. This was the point I was making. They (either manually or...
SC (temporarily) stops NCAP
