Results 1 to 10 of 13
- Sep 2003
- 75
October 11th, 2004 04:37 PM #1Please post how many liters of oil are needed for the following engine sizes:
1. for 1000cc-1500cc engines
2. for 1600cc-2000cc engines
3. for 2.2 lt. – 3.0 lt. engines
4. for 3.2lt. – 4.0 lt. engines
5. for 280HP - 350HP engines
6. for 400HP - 500HP engines
Many thanks in advance!
October 11th, 2004 04:59 PM #2
Weh?
1.6 liters, usually 3.5 liters of oil
2.0 liters, around 3.75 liters of oil.
This varies per model and engine, but that's the general rule.
I don't know about 2.2 ltr - 4.0 ltr engines. Maybe someone else can help.
There is no general rule as to the oil capacity of engines depending on horsepower. For example, a 2.0 liter 4G63 Evo engine requires maybe 4 liters of oil, and produces the same power as a 5.7 liter V8, which would require more than 10 liters of oil. It really just depends on the size of the engine.
- Sep 2003
- 75
October 11th, 2004 05:06 PM #3Thanks niky for the info. Approximate lang naman ang kailangan ko for the engine size ranges.:nerd:
- Aug 2004
- 223
October 12th, 2004 03:35 AM #6sir peace tayo ha.
sir, siguro naman po kung bumili tayo ng auto may owners manual po naman po un. dun na lang po natin verify kung ilan talaga ang kailangan na langis ng engine natin para mas safe bago tayo maglagay at bumili kung ilnag liters na gagamitin natin. thks po.
peace po
October 12th, 2004 07:35 AM #7
my 3.0 liter ZD30 engine uses 8.1 liters of oil. earlier models of the same engine uses only 6 liters of oil. after they found out it was not enough (crank case cracking), they modified the oil pan to a bigger one to accomodate more oil.
Signature
October 12th, 2004 10:05 AM #8
Suzuki Samurai 1.3 l - 3.5 liters
Pajero Gen1 4D56 2.5 NA - 7 liters
Nissan Patrol TD42 4.2 l - 11 liters
Toyota Corolla XL 1.3 - 3 liters
Toyota Corolla DX 1.4 l - 4 liters
October 12th, 2004 11:15 AM #9
Accdg to the owner's manual, the 4A-FE (1.6L) requires 3.2L of oil. Pero nung sinalin yung 4L container, parang mga 0.5L na nga lang ang natira... Hmmm...
October 12th, 2004 09:28 PM #10
Ganuun usually... whatever the manual says, most 1.6s only take 3.5 liters to get to the F mark on the dipstick.
have your compression checked... if Manual yang Montero mo... try mo patulak if ayaw mag start...
