I had the throttle body of my mitsubishi 4G15 cleaned. i was able to remove too much black and sticky substance from the TB and the throttle flap. In the process I had all electricals (sensors) disconnected including the throttle position sensor, and the ones behind the throttle cable, but not the Idle Air Control Valve though. When I run the car afterwards, idle goes upto 1500 on start-up for 5 seconds, then settles at 1000 to 1200 with AC off. When AC is on it is about 900 rpm. Seems a little high from previous setting of 800 rpm. I tried to adjust the idle screw to lower the base idle, but that doesn't seem to work. I have almost completely loosen the screw but the idle is still up. Also the check engine light (CEL) appears when at idle and AC off. But when AC compressor is on or when i step on the gas, the CEL disappears. What have I messed up? the throttle sensor? Other than the CEL appearing and the somewhat higher base idle, engine seems more stable,with less shudders at stop and go after cleaning.
Any ideas tsikoteers? TIA
