Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Good Day fellow tsikoteers. Nag browse ako sa Shopee ng langis, biglang kong naisip I search ang ZiC oil. Nung lumabas ang lahat ng ZiC oils, nakita ko yun dalawang klase ng 20w-50 which is the X3 and X5. Ask ko lang kung nasubukan nyo to? Any feedbacks/reviews? Current oil na gamit ko is Petron Ultron Touring 20w-50 (API SL) on my 2006 Toyota Innova J Gas
    Thanks!
    you do not use 20w50 in a gas engine. Sobrang lapot. Magiging andar desel ka.
    Kahit sa current desel, Hindi dapat gumagamit 20w50. Yung mga gung-gung sa banawe at toyota casa gumagamit ng ganyan viscosity.
    Really? Sa experience ko, ok takbo at swabe gamit ko Petron oil. Hingi lang ako opinion at feedbacks about ZiC oil sa nabanggit kong oil type. Kung may nag Sabi pangit ang ZiC, back to Petron ako, Toyota oil or other oil brands.
    sige kugn gusto mo talaga ganyan viscosity eh pwede mo naman itry. Ok naman ang zic. Ganyan din gamit ko pero 10w40, 5w30 and 5w40.
    Jan 2008
    20w50 is ok for high mileage gas engines.. pero mas recommended ang 20w40
    Jan 2008
    Quote Originally Posted by drich_enriquez View Post
    Hindi naman panget yung zic... yung viscosity na gamit mo ay masyadong malapot.. kung high mileage na yan engine mo say 200k kms na tinakbo.. ok yan 20w50..
    Ask ko Lang ok lang sa Innova ko although hindi nakalagay sa owner's manual ang 20w40?
    Nasa 185k na ang mileage nito sir yapoy.
    Check your manual for oil recommendations. Do not use 20w50 on gas engines even if older models unless it’s the only option available. I learned my lesson before when I cheaped out on using 20w50 on my old 2001 Accord. I changed it after a month of use.
    20W50 was our mainstay motor oil in our 60s-70s cars.
    what happened, when you used 20W50 ?
    The engine warmed up slower compared to an oil with 5w40 viscosity. It also feels sluggish to rev to higher rpms. VTEC engines love to be revved high so using such a thick viscosity defeats the purpose.
    It may work with 60s or 70s or 80s era vehicles but cars at the turn of the century, better go with 5w40.
    Jan 2008
    Minsan kasi 20w50 oil is good para ma compensate mo kung medyo nag consume na ng oil yung engine.. kasi pag old engine at mainit na.. lumalaki din yung tolerance ng mga gaps nyan resulting to oil consumption.. band aid solution is to use thicker oil..
    Pero on regular use. Dapat 20w40 lang..
    Ngayon sa tanong na ok ba yung Zic oil.. Ok na Ok yan
    15w40
    20w40 isnt standard
    Feb 2020
    15w40
    20w40 isnt standard
    Refer always to associated tech manual re grade of oil to be used e.g. 5W40.
    My understanding is that the 5 stands for lower viscosity during cold start as the bearing clearances are still tight. The 40 is for desired viscosity at normal operating temp. for tropical regions.
    Jan 2008
    15w40
    20w40 isnt standard
    Madalas 20w40 pang gas engine.. yung 15w40 pang diesel or gas din..
    Sa tropical country yung 40 ang mas recommended
    Thanks!
    whats making you change your oil of choice? any symptoms?
    I would get any multigrade 15w40 thats api-sl (shell is very good but the pricing is not as good as the imported ones.) 20w50 is a little thick imo.
    Aug 2004
    Never saw 20w40. Used 20w50 on my 1996 Lancer. Used 15w40 on my 2011 Vios. 15w40 is common din sa diesel so if you're getting that viscosity make sure you get the right product for your engine type.
    Same here, tell us your experience? (Altough 20w50 user me).
    Sir anong brand ng 15w-40 oil na ginamit mo sa Vios? Mobil and Petron (Touring 15w40 released last year) lang ang alam kong 15w40 gasoline engine
    Ok naman smooth naman ang takbo ng Innova wala naman symptons. Curious lang ako dahil X5 (Blue Bottle) 20w-50 na semi synthetic oil. Previous gamit ko is Multigrade oil. Kadalasan ang Semi Synthetic nasa 10w-30 at 10w-40.
ZIC 20w-50 oil X3 (Multigrade) & X5 (Semi Synthetic) any feedbacks
