Results 1 to 10 of 20
- Nov 2002
- 27
January 27th, 2003 01:22 PM #1guys, can you suggest good replacement air/oil/fuel filters for the TD27 of my frontier. i will appreciate if you can also specify the price estimate and where to get them. thanks.
January 28th, 2003 11:28 AM #3
Yup, ViC.
- Nov 2002
- 27
- 67
January 28th, 2003 02:02 PM #6
Pero sa air filter, kahit ano na lang ang ginagamit ko, eh. Hehehe. Basta replace every 5K kms.
January 30th, 2003 03:59 AM #7
otep
dapat ba every 5k palit ng air filter,kc ako 50tkm na di pa nagpapalit,magkano ba air filter
Tsikot Member Rank 3
- Dec 2002
- 636
January 31st, 2003 01:27 PM #8jay crew
The air filter is just as important as a clean oil filter. Any dust that gets thru the air filter will contaminate the oil and cause added wear and tear on engine internals. I've seen damage on engines that were caused by poor fitting or neglected air filters inspite of the regular oil changes. :shock:
Try Vic replacement air filters too but you'll need the orig part no (OEM) to find the right Vic part no. Diesel air filters cost about P300-500.
I replace mine every 10tkm which is when a vacuum sensor on the air filter box signals a decrease in the air flow within. Doesn't matter if you do city or highway driving but may change more often on dusty gravel roads.
January 31st, 2003 03:02 PM #9
jackaroo
tnx a lot i think i badly need a filter change consideringmy ride is almost 3 years old.
btwhow often do you need an oil change,tnx again
January 31st, 2003 03:16 PM #10
try nyo rin dito peeps:
NBSQ ENTERPRISES (oil/air filters/plugs/other accessories)
Nancy Lim - Prop.
529 San Nicolas St., Binondo, Manila
Tel nos: 743-9141 / 731-6113
sila na yata isa sa mga pinakamura ang presyo kapag wholesale...di ko lang alam kapag retail...
