Results 1 to 3 of 3
- Sep 2013
- 153
January 29th, 2014 04:48 PM #1Hi,
Just wondering is there is a difference when you say that your car has an ECU or a computer box?
Are fuel injected engines classified as engines with ECU or computer box?
- Nov 2009
- 3,509
January 29th, 2014 06:13 PM #2ECU may mean Electronic Control Unit w/c is a computer box controlling a specific part of the vehicle. Older vehicles usually controlls only the engine hence they call ECU as Engine Control Unit. Newer vehicles have separate computer for Engine management, Powertrain, Body Control, Airbag, Transmission, Suspension, etc.. Like a computer, all these control units communicate thru a common bus. Each units could be pre-programmed, run an application specific code, self-learn from the user behavior thru the map.
Fuel injected engines w/c do things like ignition timing advancement/retardation, air fuel mixture, etc.. is controlled by ECU or ECM (Engine controll unit/module).
- Sep 2013
- 153
VinFast VF 3
