Page 6 of 8 FirstFirst ... 2345678 LastLast
Results 51 to 60 of 73
    May 2019
    #51
    But you can supervise, I even bring my own tools that I buy in the US for the mechanic to used and instruct carefully. step by step what should be done at least accordinf to the service manual that I could find on the internet. That's the advantage of living in PH, labor is cheap. DIYing without doing the actual dirty works. [emoji3526]
    It’s ok, chicks dig strong, rough and manly hands..
    #52
    Quote Originally Posted by Wave24/7 View Post
    Hmmmm...this may be more theory than practice, sir. Got rough hands, but no diggin' anywhere.[emoji16]
    #53
    Dapat long fingers pa. [emoji23]
    #54
    Makes it very easy for crazy people to pull a prank ...
    hard to tell whether the car has a stopcock or a bolt.
    meaning to destroy an engine by draining it of oil, is not a prank.
    and if they really want it, the wrench is almost as easy.
    stealing the spare tire is probably just as easy, and more profitable, too.
    Sep 2010
    #55
    Salamat mga boss. Dalhin ko nalang ulit sa casa ung unit ko at i-avail ung change oil promo nila dahil magka presyo na halos vs non-casa shops na pinag tanungan ko.
    Cheers!
    Jul 2019
    #56
    Those are crush washers designed to get compressed to maintain a good seal with the pan. Used ones might not seal well anymore. That's why it's prudent to just replace them every oil change.
    Totally agree. it's better to spend few bucks more to avoid leakage overtime. than to drain the whole pan just to replace the faulty washer. some washers are made of copper or alu and some are with rubber lip on the inner dia. Some service shops are using a suction pump with the hose inserted on the dipstick tube down to the bottom of the pan to drain the oil.. that leaves the drain plug untouched in its place permanently.
    #57
    Quote Originally Posted by nelyoung View Post
    Makes em good candidates for seized plugs.
    Jan 2008
    #58
    Installed the fumoto valve.. nice fit to my 4d56 engine!
    The package comes with a fumoto clip and the seller included the plastic nipple with hose extender..
    The valve does not protrude.. just like the old drain plug.. its just longer by 10mm and in no way can be hit by rocks underneath..
    #59
    congratulations, travs!
    you have a convert!
    best wishes to you, too, yaps.
    Apr 2014
    #60
    So tama ba 2.5k nga? Based sa fb search.
    Or cheaper?
Does drain plug washer is really required to replace every oil change?
