Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Kung both filters po ay pupwedeng ikabit sa car ko, which one should I choose and why? Anu pong advantages and disadvantages of both type of filters? Any brand na mas ok?
    Jul 2005
    pare parehas lang yan kasi papalitan mo rin naman yan taon taon e.
    um, materials?
    The steel filters are usually on EFI cars whilest the plastic ones are used for carbed vehicles (different fuel pressures?).
    Sep 2004
    Quote Originally Posted by gwapito69
    yearly ba palit ng fuel filter?!
    Quote Originally Posted by albert_b
    every 20K km
    VIC or Bosch are good brands
    may kinalaman ba ang fuel filter sa fuel consumption ng isang kotse?
    materials ang difference pero mas superior ang filtering ng metal case filters. cheaper yung plastic (white) saka makikita mo kung madumi yung loob unlike sa metal. sa diesel mas ok yung filter with metal casing although may mga nakikita ako na primary fuel filter nila yung metal tapos secondary nila is yung plastic.
    Quote Originally Posted by ravelcop
    wala pong kinalaman. wag lang may tagas yung filter (j/k)
    Aug 2004
    Lahat ng filters may kinalaman sa fuel consumption IMO. Nung nagpalit ako air AND fuel filters tumaas ang mileage. Kahit ihataw di pa rin bumababa to the same level nung lumang filters pa gamit ko.
    Ah dapat pala 20K Km palit metal or plastic man ang gamit. Tsk tsk... I think its decade old. Hahaha. Mahal daw kasi 1K?
    Jun 2004
    Mas maganda rin ba original filter (honda) gamitin or kahit replacement lang?
    Quote Originally Posted by chris_d
    Orig pag steel sabi sakin. Sa carb namin replacement a bnew syempre.
    Jun 2005
    kapag barado ang fuel filter, especially plastic type. ang effect sinisinok ang sasakyan. pagdating sa 3rd gear pataas lalo.. i mean hindi ka makaarangkada. it happens sa amin yan ng pauwi kami sa manila galing pangasinan
    parang 40k yata pwede pa din maski di mo palitan ang filter na steel. yung sakin 48k na tinatakbo since magpalit ng fuel filter until now ok pa din sya. Pero syempre depende din yan kung may dumi sa tank or sa fuel lines mas mabilis kang magpapalit ng filter.
    Some cars have a clear plastic fuel pre-filter and a metal main filter.
    minsan i had this problem na namamatayan ako ng engine during cold start sa umaga. kung anu-ano na pinaggagawa ng mechanic ko, hindi parin ma-solved. pinalitan ko lang ng fuel filter, solved kaagad!
    Jul 2005
    what are the indiciations kapag puno ang fuel filter? yung sa ae92 ko puno lagi, diba dapat half full lang? Thanks.
    guys, if you were to choose wherein either metal or plastic filter may be used in your car, which one would you choose?
Difference between steel & plastic fuel filters
