Results 1 to 14 of 14
    Jul 2010
    To all tsikoteros magandang umaga po.
    I have some trouble again and again po sa engine ko. it is a owner type jeep with a 4K engine and with a 4 speed tranny.last saturday we travel sa dau pampanga using NLEX highway....since i was on the 4th gear biglang namatay ung makina.kapag nagstart ako umiikot bcoz of the battery but hindi tumutuloy.then nakakita ako ng mekaniko at ginawa nya.then adjustment sa ignition for timing again..nagstart xa but after non tumakbo kami namatay na naman ung makina.sana po kung merong pong kayong magaling na mekaniko ragarding dito near po ako sa welcome rotonda.and share naman po ung mga ideas nyo base sa nobela ko...more power!
    [SIZE="4"]REMINDER: do not post messages with SMS/TXT shortcut format.
    Read the rules.
    Ignorance of the rules is NOT an excuse.
    Repeated offenses will lead to banning.
    Have a nice day.
    [/SIZE]
    Apr 2004
    palagay ko nagooverheat ka ng hindi mo alam... sira ba temp gauge mo?
    o kaya barado carburador mo.
    o kaya talagang wasak na makina mo pag umikot ng mabilis nawawala na sa tamang adjustments.
    o sira na ignition coil. pag iminit nawawalan ng output. pag lumamig ayus na naman.
    It could be a lot of things.
    It could be the coil - kaya lang sabi mo nasa 4th gear ka na at mataas ang rpm mo na. Kapag on idle lang lumalamabas ung problema sa coil.
    Most probably eh fuel related yan. nag palit ka na ba fuel filter? Baba tanke then linis carb? Nasa ayos kaya adjustment mo ng float? Malakas pa kaya ang fuel pump mo?
    Pag mahina kasi fuel pump eh madalas sa high speed mo mararamdaman.
    Pede rin loose compression kung lagi ka namamatayan ng spark plugs.
    Quote Originally Posted by fizzy_argie View Post
    Palagay ko sir overheating nang di mo napapansin yan, sira po ba yung fan niyo to dissipate the heat and your temp gauge???
    Sir if you need a very good mekaniko po na mapagkakatiwalaan just pm me po I will refer you to my mechanic trusted ko na po ito and sure ball po kayo sa kanya... Just pm me po.
    Thanks.
    Dec 2009
    +1 ignition coil
    Nov 2006
    Quote Originally Posted by RedAxel View Post
    +1 ignition coil
    +1 din sa coil. maski high speed nagiinit ang coil. sakit yan ng 4k na makina, di rin pwede mabasa. palitan mo na lang ng sealed na igniter. di porke luma car di na pwede ibyahe sa malayo. kalokohan yan, owner ko nga 1972 ko pa nabili JIffy with 2R engine binabyahe ko pa sa nueva vizcaya at nakakasabay pa sa car ko...
    Sep 2009
    ganyan din sa pinsan kong owner jeep 4k engine . daming pinalitan fuel pump, sparkplug, caburador, distributor cap at sabay change oil.. tamakbo din ng maganda.. after ng ilang oras namatay pa rin.. nang tiningnan parang natunaw raw yung contact point ng distributor cap kaya inayos ulit...ayun tumakbo na naman... still under observation pa rin ngaun..
    May 2004
    before na nangyari ito, when was the last time na nagamit mo sya sa nlex(or any superhighway).
    Jul 2010
    Mga tsikoteros bali dinala ko napo ung owner ko sa trusted namin na mekaniko...nagpalit kami ng spark plug then ok na ung takbo...dinala pa namain ni misis sa cavite after ayusin....but there is a problem while im driving...nagstop over kami sa tindahan so pinatay ko ang makina...then pagstart ko parang need mo pang ikondisyon ang makina para umayos ung idle nya...i hope matulungan nyo po ako sa long term na problema ng owner ko..more power
    Jul 2010
    Quote Originally Posted by voltscastillo View Post
    Aray ko naman sir...parang nawalan kaagad ako ng pag-asa doon sa huli mong statement..hehhehehehe. pero alaga ko po sa tubig ang radiator ko at ok naman po ang temp gauge ko.
    Alam mo ang 4k ay isa sa mga matibay , maasahang makina, mura piyesa at marami mabibilan, matipid sa gasolina at madaling gawin pag nasiraan ka . Tandaan mo 4k carburator type engine pag ayaw umandar gasolina at kuryente lang ang titignan mo . Kung isa ang wala hindi aandar makina . Kagaya ng inihinto ka ibig sabihin sa kuryente me problema. Iyong sa akin 15 years na hangang ngayon hindi pa naoverhaul makina at kondisyon pa rin dahil alaga sa change oil .
OLd Engines cannot travel a long way???
