Results 1 to 10 of 14
June 4th, 2014 10:51 PM #1
I have a Corolla GLI 93 model na nasiraan ng servo before na nag-cause ng sira sa ECU. ECU has been fixed pero di kame makakita ng match na servo so walang servo GLI ko for a couple of months na. Ano consequences nito on engine performance? Di kaya may masira sa engine? Affected din ba RPM ng car? Pansin ko kase low RPM ako when running. Di man lumalampas ng 2000 rpm.
June 5th, 2014 09:18 AM #2
effects:
- possibility of stalling
- abnormal acceleration and idling
- high fuel consumption
June 5th, 2014 11:53 AM #3
June 5th, 2014 12:02 PM #4
- Oct 2009
- 2,271
June 5th, 2014 02:38 PM #6pag nalagyan yan ng servo siguradong titipid pa sa kunsumo yan..
kaya wag mo ng patagalin pa..
hindi ba umiilaw ung CEL mo..kahit walang servo?
June 5th, 2014 10:11 PM #7
Nalinis na throttle kanina, from 800 idle naging 900 idle na sya.
Hirap po kase humanap ng match na servo. Ganun ata talaga sa servo ng GLI, pahirapan sa ngayon.
Di naman po nailaw check engine ko kahit wala si servo. May kinalikot yung mekaniko ko nung masira yung servo kaya di nailaw check engine.
June 7th, 2014 05:49 PM #8
Just an update, nawala din yung nginig sa engine since nalinis throttle body. Before basta malamig si engine at nagstart may nginig sya. Now nawala na yun.
Normal lang ba na kapag mainit na engine eh tataas ng konte RPM kapag idle? Sensya na noob po, 1st time car owner and is still learning.
- Jul 2010
- 570
June 7th, 2014 11:19 PM #9Baka tinangal yun bulb ng check engine.
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
