Results 1 to 5 of 5
    May 2009
    Hello po mga fellow tsikoteers,
    Just got a problem with my corolla small boy 1990 GL 16valve with 4AF engine...nawalan po ng spark sa spark plug nacheck ko na din po kung may supply yun distri meron naman po...tapos pinalitan ko na din yung Ignition COil nung replacement na circuit ayaw pa din, then pinalitan ko din ng igniter but the problem ay hindi match pang 4AFE engine sya and also ignition coil na original....kasi yung original part no. ng pang 4AF is 89620-12340 pero pang 4AFE is 89620-12440...bae iba yung location ng kabitan ng pick-up coil nasa gilid instead na nasa taas...
    Tulong naman po kung may nakaexperience na ng ganito dito sa forum na ito may nagaalok dito na mekaniko na 4500petot for the distributor...saan po kaya mura sa Evang?or sa banawe?share naman po kasi namimis ko na yung corolla ko kasi parang nagtampo nung nakabili ako ng crosswind saka sya nasira..
    maraming salamat po Admin and fellow tsikoteers..looking forward sa mga replies and tips...GBU!!!have a nice day..
    Sep 2004
    Baka yung culprit ay yung High-Tension Wires? Tutal sabi mo naman ay may kuryente sa distributor? Pinalitan mo na rin ba yung isang spark plug na walang kuryente?
    Apr 2008
    baka may problema ang distributor cap mo sa ilalim nyan yun pinaglalagyan ng connection ng hi tension wire mo yun naka usling apat na tanso kelangan linisin
    May 2009
    hello po...
    just repaired my corolla and its now working..the problem is the igniter assy it is were the signal generator wires (red and white) installed....ok na po..just buy a whole distributor from the net...kaya may reserba pa ako ignition coil and the whole distributor...
    thanks po....
    OT baka may naghahanap ng distributor benta ko na lang mura igniter lang ang kulang nun ang rock and roll na...
    thanks tsikot admin...
    May 2009
    Jaz,
    Magkano mo benta ung dist? Thanks!
    Otep
Corolla Small Body 4AF Engine nawalan ng kuryente sa Spark Plug
