nakapag inquire ako kay KIADOHC sa protegetech.....sabi nya pwede daw gamitin yung engine ng Lynx, or yung engine ng 1st or 2nd generation na Mazda 323/Familia.
Added info: KIA Pride = Festiva
phillipogi, i am sure makakatulong 'to sa'yo. According to website, Mazda B6 SOHC ang bolt-on and can reuse other stock parts..Hope it helps.
philippogi thats a good project, considering not that many peeps wud dare tinker on their kias. while your on your way to that switcheroo, y not try converting it to the USDM kia? AFAIK, the kia pride cd5's US counterpart was the Ford Festiva. Ive seen a couple of festivas running around ortigas. they look good to me. if i had a cd5 id probably try to convert it into a festiva. yun nga lang all the festiva parts and accesories are bitch to find here sa pinas. so it will take some time. kind of like restoring a Mini.
Try mo check http://www.FordFestiva.com
Here's another one. http://www.festivamotorsport.com/projectcars/festiva/festivaintro.htm
FerioEG9Boi, the red car that you posted uses a Mazda 121 Headlight and Grilles and the bumper came from a Ford Festiva GTX. Naka Ford Festiva GTX front cut ako pero yung bumper ko hindi ko pa kinakabit.
Bhords69, the B6 that you mentioned is not the B6 that is available in 323 that are sold here in the Philippines. It is not a 16-Valve mazda engine but a 8-valve B6 mazda engine that exactly looks like the stock 1.1L engine of the Kia Pride. It has bigger bore and stroke and a bigger intake and exhaust ports and of course bigger itake and exhaust valves.
The B6 that you are refering is rarely imported here from Japan. I only saw one installed in a Kia Pride(ka race ko dati sa libis-Ryan). I previously tried the B5 version and had 17.8sec. 1/4mile. It costs around P12K, pero why will you buy & install a still weak engine kung puwede naman ang mas malakas, tapos mas mura pa. Refer to www.protegetech.org(im the kia pride owner that always post at their forum, iba lang ang username ko outside that site)=I prefer that all questions and sharing are posted in www.protegetech.org.
Phillipogi, nag post ka na yata sa Protegetech.org. Meron akong on-going project ng engine. Nagpakabit siya in carbureted form. Binigay ko lang free yung labor. Puwede ka naman bumili muna ng makina tapos dahan dahan ko gagawin ang conversions sa engine, para dahandahan labas ng pera mo for the swap. Im selling the engine for P10K only.
Kasya ang 14" na mags sa Kia Pride. nakakita pa nga ako ng 15"
KIAALLMOTOR: Thank you for the info, matagal na rin akong nag-aabang ng info kung paano mapapabilis ang performance ng KIA car ko and for me it's a challenge. Right now my car is under repainting and engine maintenance. Ilang araw kaya ang swapping until fully run plus magkano? Priority sa akin ang time duration?
Planning to change my tire into these two options: 185-60 R14 or 185-50R14, Alin kaya mas maganda sa dalawa at anong mags ang bagay?
Another Q is where I can get accessories to dressed up my KIA (sedan)?
Nasa manila kasi ako after new year and planning to buy accessories for it...Thanks
